1. Yousef Mohamed's Avatar
    So i have this problem, im not sure which one is my sd card, when i go to options in my phone there is storage options and there is
    Phone Storage
    Internal storage
    Let system decide..
    So, which one is my sd card?
    And why does my phone keeps on saving app on my phone storage i mean, i have 8 gb sd card, why it doesent save it there?
    08-29-2013 01:16 PM
  2. srkmagnus's Avatar
    Phone Storage
    Internal storage
    Let system decide..
    By default, the device will save files and downloads to the internal sd card. You need to change the default download location to the external sd card, which can be done in the storage settings of the device. Note: Not all files can be stored to the external sd card by default, i.e. Apps.
  3. srkmagnus's Avatar
    Phone Storage
    Internal storage
    Let system decide..
    Golfdriver97 likes this.
    08-29-2013 01:58 PM
  4. B. Diddy's Avatar
    Ok, so this is a bit puzzling, and I wonder if you could post a screenshot when of when it asks you to choose. Phone Storage and Internal Storage are usually one and the same. Phones will break their memory down in one of 2 different ways:
    1. Older phones usually have 3 possible memory partitions: (a) Application Storage, which is anywhere from around 512 MB to 3 GB. This is where apps are installed, and where some app data is stored as well. You shouldn't be able to store anything yourself in Application Storage. (b) Internal Storage aka Phone Storage aka Internal SD, which is the main part of your phone's advertised memory that you can use to store data or media files. Apps can store data here as well. If your phone was advertised as having 16 GB of memory, the usable Internal Storage is typically only around 8 GB after accounting for the OS, bloatware, and Application Storage. (c) External SD card, which is obviously the SD card that you insert into the phone. Unless you root your phone, the external SD card is mostly useful for storing lots of media files. Some (but not all) apps can also store data on the external SD.
    2. Newer phones have so-called unified storage, where there is no breakdown for Application Storage and Internal Storage. When you look at the Storage menu, you should just see two graphs of storage: Internal Storage and External SD card.
    Now, in your case, we need to make sure that your device is recognizing your external SD card. Go to Settings/Storage, and make sure there is a separate storage graph for the external SD, apart from the Internal Storage. If you see it, then it should be available.
    Next, we need to know what situation brought up the options of storing in Phone Storage, Internal Storage, or let system decide. As I mentioned above, this shouldn't happen, because Phone Storage and Internal Storage should be the same thing. So try to post a screenshot of when those options come up, and also post a screenshot of your Settings/Storage menu.
    08-29-2013 11:58 PM
  5. vrajesh shah's Avatar
    Hi,
    I want to know which place documents are stored in SD-card of Android phone?
    At which location documents (like pdf, wordfile, ppt, textfiles etc..) are stored?
    04-21-2014 12:07 AM
  6. B. Diddy's Avatar
    Welcome to Android Central! It really depends on which app you're talking about, or if you're downloading a file from the web. Apps will usually have their own specific folder where documents or files are stored. If you're downloading a file from the web, it will go to the main Downloads folder--unless you're using certain browsers that might have their own download folder.
    04-21-2014 12:20 AM
  7. namrata saha's Avatar
    Phone Storage
    Internal storage
    Let system decide..
    09-12-2014 01:17 AM
  8. B. Diddy's Avatar
    Hi!
    09-12-2014 01:24 AM
  1. Upgrading to Note 4: Keeping Unlimited Data
    By chuckawd in forum Verizon Galaxy Note 2
    Last Post: 02-10-2015, 08:13 PM
  2. Replies: 38
    Last Post: 09-28-2014, 05:52 AM
  3. If you were wanting to buy a chromebook
    By DaManx22 in forum Chromebooks
    Last Post: 09-26-2014, 08:43 PM
  4. Nexus 6 to get T-Mo's WiFi Calling?
    By someguy01234 in forum Google Nexus 6
    Last Post: 09-18-2014, 03:34 PM
  5. How to Split Navigation and Status Bar on the Bottom (Tablet UI)?
    By too lame to come up with a good username in forum Google Nexus 7 (2013) Rooting, ROMs, & Hacks
    Last Post: 09-18-2014, 12:53 PM
