LED Indicator Light Not Turning On
CursiveTea
4
So not really sure if this has already previously been discussed, but I thought that I would share the fix to my problem on here. I searched here before and couldn't find the answer, so here goes. LED indicator not showing up on your Note 2? Even after doing the *#0*# test only to find out your LED is in fact working, just not showing notifications? Then perhaps you may have Blocking Mode enabled. Now, I never marked this box and only assume that it came on either after a re-boot or updates, but I re-booted and saw it still in my notification bar, clicked on it and saw LED Indicator was set to off. I marked the box (or just disable blocking if that's your choice), and that solved my problem. I knew LED was fine because my phone is new and the light was showing up when I was re-booting, just not staying on. Now if it is not listed in your Notifications because it's not turned fully off and maybe only 1 setting is marked, it can be found in: Settings, Devices; underneath Home Screen Mode. Hope that helps some of you.
Thank you, glad to be of any help to anyone. I posted it as soon as I figured it out because I was baffled and thought that my new phone had errors all over the place with no alarm, no notification light etc. Lol.
Thanks! Other members will definitely find this useful if similar problems occur with the indicator.
Lelix2603
