Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Scott Kenyon
  • 1 Post By Abhishek Raj1
    Sundar Scorp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Sim 1 not working on Micromax Ninja 3
    I tried the *#*#4635#*#* in my mobile. It showed me a menu and i clicked n "Phone Information" and selected "SLOT 1". It showed some network options below. I tried to change them to some other values.
    Initially it was "GSM only", i changed to some other random values. I hit on "Radio On/Off" buttons sometimes. Now, the tragedy is that, my SIM 1 not working at all.
    I tried from Soft reset to hard reset. Nothing works. It wont detect any sim cards.
    When i try to enable the slot by "Settings-> Dual Sim Settings-> Configure DUal Card, it throws "The process com.android.phone has stopped unexpectedly. Please try again"
    I am lost in island. Please help me...
  2. #2
    Scott Kenyon's Avatar
    Posts
    Global Posts
    2,189 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MoDaCo Switch Beta 8
    Default Re: Sim 1 not working on Micromax Ninja 3
    Follow these steps exactly and let us know if your problem is solved:
    Official Stock ROM for Micromax A57 Ninja 3
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Scott Kenyon View Post
    Scott,
    Thank you for your quick response. I tried the way already. But, will try one more time and let you know the result in next hour or so.
  4. #4
    Posts
    Global Posts
    2,189 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by Sundar Scorp View Post
    Scott,
    If it doesn't work, call your carrier or manufacturer and tell them it happened on it's own. Deny doing anything with the settings and get it replaced.
    Sundar Scorp likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tried stocking twice. No dice. Will try to contact service center itself. Thank you for your suggestion
  6. #6
    Posts
    Global Posts
    2,189 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Sorry I couldn't be of more assistance. Living in the States, we don't see many dual sim phones.
  7. #7
    Newtonestine Rakib's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hey scott same problem....but can you give me the stock rom of micromax bolt a54...thnks in advance
  8. #8
    kpatil251's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    bro I am also facing same problem plzzzz tell me what to do plzzzzz
  9. #9
    kpatil251's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    bro what you have done plzzz tell me I have also done that procedure
  10. #10
    Abhishek Raj1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Srbp Sudipta likes this.
  11. #11
    Srbp Sudipta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried the *#*#4635#*#* in my mobile. It showed me a menu and i clicked n "Phone Information" and selected "SLOT 1". It showed some network options below. I tried to change them to some other values. Initially it was "GSM only", i changed to some other random values. I hit on "Radio On/Off" buttons sometimes. Now, the tragedy is that, my SIM 1 not working at all. I tried from Soft reset to hard reset. Nothing works. It wont detect any sim cards.
    Plz help me
  1. Nexus 4 screen crack - Home/Back/RecentApps bar not working
    By Prasanchand Shantilal in forum Google Nexus 4
    Last Post: 09-13-2013, 04:09 PM
  2. LED Indicator Light Not Turning On
    By CursiveTea in forum General Help and How To
    Last Post: 09-04-2013, 03:39 PM
