1. MasonM77's Avatar
    So my aunt recently gave me her old HTC Thunderbolt. Ive tried doing a factory reset through settings and also through the volume down/power button but neither worked. Every time i try to do a factory reset it brings me back to the boot loader screen and says ***LOCKED***SECURITY WARNING***. I also tried loading the stock RUU onto the phone but it says *MAIN VERSION IS OLDER and wouldnt accept the RUU I put on the SD card. Any ideas how I can get this phone to factory reset? Or where I can find a stock RUU that will work? Thanks in advance!
    Phones current software: Android 4.0.4 Ice Cream Sandwich
    Bootloader screen says:
    MECHA XD SHIP S-ON
    HBOOT-1.08.0000
    MICROP- /
    RADIO-2.02.00.1117r
    eMMC-boot
    Jun 28 2012.14:56:09
    09-08-2013 04:08 PM
  2. srkmagnus's Avatar
    Is there a SIM card installed? I'm pretty sure the Thunderbolt is a world phone and one could be installed, which may be the reason why its not allowing the reset.
    Remove it and the battery and wait a few minutes. Install the battery (not the SIM) and see if you can factory reset afterwards.
    Sent from my SPH-D710 using Tapatalk 2
    09-08-2013 04:43 PM
  3. MasonM77's Avatar
    There is not a SIM card installed
    09-08-2013 06:19 PM
  4. srkmagnus's Avatar
    OK, and removing the battery didn't help either?
    09-08-2013 07:49 PM
  5. MasonM77's Avatar
    Removing the battery did not help. I even tried putting in a SIM card and resetting and it still brings me back to the boot loader saying ***LOCKED***SECURITY WARNING***
    09-08-2013 10:46 PM
  1. HELP! ActiveSync Not Working Properly HTC One.
    By chriskir in forum HTC One M7
    Last Post: 10-01-2013, 06:40 PM
  2. Replies: 1
    Last Post: 09-08-2013, 03:29 PM
  3. Help
    By Jay Sacks in forum Verizon Galaxy Note 2
    Last Post: 09-08-2013, 03:06 PM
  4. Replies: 2
    Last Post: 09-08-2013, 01:59 PM
  5. hey guys can you help please :/
    By Red_Berry_21 in forum Samsung Galaxy S3 Mini
    Last Post: 09-08-2013, 01:23 PM
