Results 1 to 5 of 5
    Default HTC Thunderbolt Won't Factory Reset. Help Please!!
    So my aunt recently gave me her old HTC Thunderbolt. Ive tried doing a factory reset through settings and also through the volume down/power button but neither worked. Every time i try to do a factory reset it brings me back to the boot loader screen and says ***LOCKED***SECURITY WARNING***. I also tried loading the stock RUU onto the phone but it says *MAIN VERSION IS OLDER and wouldnt accept the RUU I put on the SD card. Any ideas how I can get this phone to factory reset? Or where I can find a stock RUU that will work? Thanks in advance!
    Phones current software: Android 4.0.4 Ice Cream Sandwich
    Bootloader screen says:
    MECHA XD SHIP S-ON
    HBOOT-1.08.0000
    MICROP- /
    RADIO-2.02.00.1117r
    eMMC-boot
    Jun 28 2012.14:56:09
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    6,754 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: HTC Thunderbolt Won't Factory Reset. Help Please!!
    Is there a SIM card installed? I'm pretty sure the Thunderbolt is a world phone and one could be installed, which may be the reason why its not allowing the reset.
    Remove it and the battery and wait a few minutes. Install the battery (not the SIM) and see if you can factory reset afterwards.
    Sent from my SPH-D710 using Tapatalk 2
    There is not a SIM card installed
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    6,754 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Quote Originally Posted by MasonM77 View Post
    OK, and removing the battery didn't help either?
    Removing the battery did not help. I even tried putting in a SIM card and resetting and it still brings me back to the boot loader saying ***LOCKED***SECURITY WARNING***
  1. HELP! ActiveSync Not Working Properly HTC One.
    By chriskir in forum HTC One
    Last Post: 10-01-2013, 06:40 PM
  2. Replies: 1
    Last Post: 09-08-2013, 03:29 PM
  3. Help
    By Jay Sacks in forum Verizon Galaxy Note 2
    Last Post: 09-08-2013, 03:06 PM
  4. Replies: 2
    Last Post: 09-08-2013, 01:59 PM
  5. hey guys can you help please :/
    By Red_Berry_21 in forum Samsung Galaxy S3 Mini
    Last Post: 09-08-2013, 01:23 PM
B
