I am on this thread because I am desperate. I am not very tech savvy and most search results use terms which I do not understand and was hoping y'all could help a poor gal in distress.
I dropped my Samsung Galaxy Attain 4G from a height of about 3 feet onto a marble floor. The battery popped out, but there is no physical damage as far as I can see. The phone automatically went into a reboot loop, by which I mean it flashes the "samsung" logo again and again. It doesn't turn on or off. After removing the battery and sim card several times to no avail, I searched some of these forums and found the 3 key combination (volume/power/home) which can be used to get a factory reset. Now, I have gotten that factory reset screen where I can scroll using the volume key, but my phone stays on that screen for about 4 seconds before reverting back to flashing "samsung." This is where I stand as of now.
Can someone give me an honest evaluation... is my phone completely done with?
Thanks.
Thanks.
