Results 1 to 2 of 2
    Question Samsung Galaxy Chat not charging correctly.
    So, I have the Samsung Galaxy Chat (GT-s5330) and I have a weird problem. When I connect it to a charger (happens on wall charger and on PC connection) it turns off immediately, and it can't be turn on whatsoever. I left it a whole night charging, and in the morning, when I disconnected it and turned it on, it had low battery and needed to be connected to the charger. I think it got wet this weekend, because it rained a lot, but I really don't know the cause of it. How can I solve it?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Samsung Galaxy Chat not charging correctly.
    Quote Originally Posted by Nick32123 View Post
    If you suspect water damage it might be wise to let is sit for a while to dry. They say placing the device (with the battery and back cover removed) in a bag with rice to suck any moisture out of the device. Let it sit for a few hours then try again. If still nothing, then consider a battery replacement - hopefully that's what the problem is. If still nothing, then it could possibly be some damage to the hardware and the device should be replaced.
  1. Samsung s4 exploding battery
    By TaySpud in forum Samsung Galaxy S4
    Last Post: 07-10-2014, 03:50 AM
  2. Galaxy S3 dying after flashing Cyanogen Nightly
    By Tarek Salama in forum Samsung Galaxy S3 I9300
    Last Post: 09-13-2013, 07:44 AM
  3. Screen does not respond
    By Madelein K in forum Samsung Galaxy Tab 3
    Last Post: 09-10-2013, 07:42 PM
  4. Battery dimensions for galaxy grand GT-I9082
    By gauti2013 in forum Samsung Galaxy Grand
    Last Post: 09-09-2013, 06:42 AM
  5. Help, Samsung setup wizard just stopped!!!
    By Cynthia Da Costa in forum Samsung Galaxy S3 I9300
    Last Post: 09-09-2013, 02:56 AM
