my s duos wont boot up.one time i didnt charge it for one day.i then charged it for half an hour and tried to boot it up but no it was not booting up.i tried after 8 hours.same result.please somebody help i beg you:''''''''''''''(
Does the Duos have a removable battery? If so, remove it then re-insert and charge again. If still no luck then consider replacing the battery and see if that fixes it. I suspect the battery might have gone bad and needs to be replaced - you can test it by spinning the battery on a flat surface. If it spins for a few seconds, then it's bad. If it doesn't and stops almost immediately then it's still good and something else can be an issue.my s duos wont boot up.one time i didnt charge it for one day.i then charged it for half an hour and tried to boot it up but no it was not booting up.i tried after 8 hours.same result.please somebody help i beg you:''''''''''''''(
