That is not particularly helpful. Many of us have multiple wifi connections (home, work, friends, etc. etc. etc.). Google claims to be backup up your wifi passwords (if you have enabled that in your phone settings). Trouble is that it often does not restore these automatically after doing a factory reset or flashing a custom rom. The question the OP had is if there is a way to force google to restore these passwords after a reset. I'd be interested in finding this out too. I have figured out a workaround though. Be sure to make a nandroid backup before doing a reset/flash rom (assuming that you have root and recovery). Using Nandroid Manager from the Play Store you can then recover the wpa_supplicant.conf file from /data/misc/wifi and put it back into the same location in your root directory. OR just copy the file and put it on your sdcard and you can copy it back to /data/misc/wifi after the reset/flash.
It would be nice if the Google backup feature would just work to restore them though. Seems to work sometimes and other times not. I haven't figured out why. Anyone?
