1. Keith Tyler1's Avatar
    Ive put music on my SD card, and the artist shows up with songs and album picture on my phone after I was done... But When I select a song it wont play... There is just a quick message that flashes about not able to play...
    What are some options I can do?
    I already rebuted,
    I downloaded other apps but all still does the same... "Nothing"
    I even tried diferent albums but all seems to do nothing when it comes to playing the song.
    09-15-2013 02:14 AM
  2. Keith Tyler1's Avatar
    I just put one album on the SD card to see what the message says.
    When I try to play a song it says "failed to play the requested stream"
    09-15-2013 02:55 AM
  3. Shadowriver's Avatar
    What SD card you got? What format your music is? do you tried to play music directly from card to PC? if not try it
    09-15-2013 03:29 PM
  1. Samsung Note 2 photo & music suddenly lost
    By annietanhn in forum Samsung Galaxy Note 2
    Last Post: 09-22-2013, 05:51 AM
  2. Will Android Apps Have Better Looking UI in the Near Future?
    By Boba7523 in forum General Help and How To
    Last Post: 09-18-2013, 02:44 PM
  3. Music Audio Quality?
    By FrankA1 in forum Moto X (2013)
    Last Post: 09-16-2013, 03:48 PM
  4. folders not showing ip when plugged into a PC
    By slave in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-16-2013, 05:05 AM
