Results 1 to 8 of 8
    Unhappy USB problem
    Hello!
    I plugged my phone (Alcatel OT-991) into my computer via USB. The phone is charging, but when I mount the SD card, it doesn't show up in My Computer.. I was looking for the solution at many forums, but I didn't find it... So, any ideas? Please, help!
    P.S.: Sorry for my bad English...
  2. #2
    Default Re: USB problem
    Check Device Manager on PC, see how your phone is visible there
    http://i.imgur.com/RCG4BD9.png This is how Device Manager is looking.
    BTW I tried connecting my phone with another computer, and there is worked without problems..
  4. #4
    Then its your pc problem thru your system see USB mass storage, you could try connecting to diffrent usb, if this does not work you could try to check system logs (right click My Computer and click manage, logs will be there) it might tell younsomething more
  5. #5
    When you plug the phone into your computer, swipe down the notification shade and select the USB notification. Make sure it's connected as USB Mass Storage, Disk Drive, or MTP.
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Have you ever had the phone plugged into that computer and working before? If not, have you installed the driver for your phone into the computer? (Some computers don't ask if you want to install a driver for some phones, you have to get the driver and install it yourself.)
    Quote Originally Posted by Rukbat View Post
    Yes, it's worked and now, when I plugged it into my laptop there's worked too. Drivers are installed.
  8. #8
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,754 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Have the drivers been updated? Sometimes that can make the difference.
  1. samsung S4 wifi problem
    By bruizer31 in forum Samsung Galaxy S4
    Last Post: 11-18-2013, 03:11 PM
  2. Verizon HTC One experiencing major problems
    By Cayderayd in forum HTC One M7
    Last Post: 09-17-2013, 12:26 AM
  3. got a problem with stock camera app
    By John Fungo in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-15-2013, 10:13 AM
  4. Sony ACRO S problems after updating to Jelly Bean 4.1.2
    By areweed in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-15-2013, 08:56 AM
  5. Dropped my Nexus 7 on hardwood floor, now experiencing battery life problems
    By Jonathan Mendez1 in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-15-2013, 06:55 AM
