Hi! I have a micro SD card that I have been using for several years now, but my tab suddenly stopped detecting it. I tried inserting it into my phone but it still wasnt detected. I also tried cleaning the pins but nothing happened.
Can I still save this? Its really important to me cos it has a lot of my files in it..
It's a 16GB micro SD card bought from cd-r king btw..
Welcome to Android Central! What happens if you insert the card into your computer's SD reader--can the computer detect anything? If not, it's probably dead. If it does detect it, then run chkdsk to scan for bad sectors: http://forums.androidcentral.com/am...guide-using-chkdsk-fix-corrupted-sd-card.html
