Results 1 to 5 of 5
    jbagnal's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question [Q] Samsung Galaxy S2 not connecting to Samsung Kies after PACMAN ROM upgrade
    Hi,
    I recently upgraded my Samsung Galaxy S2 ROM to PACMAN ROM 4.2.2. Upgrade was successful and
    everything is working fine. The backup I had taken in Samsung Kies is now becoming difficult
    to put it back to my phone. I tried all possible ways to connect my phone to Samsung Kies but
    this is not working. Due to this I am unable to restore my backup to my phone. Whenever I
    connect my phone it gets stuck in connecting message and does nothing. It used to work before
    the previous ROM.
    What I have done till now:
    1) Reinstalled samsung Kies several times (without & with phone connected). Downloaded the
    latest kies and installed.
    2) Manually installed SAMSUNG_USB_Driver_for_Mobile_Phones.exe from kies folder.
    3) USB Debugging ON/OFF both way tried - no help. (MTP Enabled always)
    4) Removed all phone entries (ADB & other entries) from device manager and reinstalled each
    drivers completely - no help
    5) Take battery off and restart while kies connected.
    6) checked different cable - no help
    7) Tried on different laptop - no help
    8) Tried connecting Kies with safe mode -
    Please can anyone help?
    Thanks,
    Jas
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,086 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: [Q] Samsung Galaxy S2 not connecting to Samsung Kies after PACMAN ROM upgrade
    Quote Originally Posted by jbagnal View Post
    Hi,
    the previous ROM.
    Thanks,
    Jas
    Welcome to the forums!
    I tried connecting mine to Kies, and it didn't after ten minutes. I think it is the fact of custom ROMs, but I may be wrong. For me it's no big loss. The only thing i update Kies for is Samsung Drivers.
    Everything else, I have an app that can back up what Kies can.
    jbagnal's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, the only mistake I did, I took my back up via Kies and now its not able to connect. I think I should have used some other apps to do this. Its definitely the ROM problem.
  4. #4
    jtcromer's Avatar
    Posts
    Global Posts
    12 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I learned this after rooting and installing a custom ROM.
    Kies does not recognize custom ROM.
    Hope this helps
  5. #5
    JessicaICS's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm also still confused about this
    Fracent.com
  1. Samsung Galaxy Grand Slow Performance after JB 4.2.2 upgrade.
    By sagarkapadia in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-11-2016, 08:13 AM
  2. Nexus 5 coming to the GPstore near you!!
    By eco7 in forum Google Nexus 5
    Last Post: 10-19-2013, 12:16 AM
  3. s3 moving to htc one possibly
    By jj2339 in forum HTC One M7
    Last Post: 09-17-2013, 08:26 AM
  4. Backing Up Android to Google Mean Giving Them Your Password
    By Haalcyon in forum General News & Discussion
    Last Post: 09-16-2013, 11:54 PM
