1. Ron Sharer's Avatar
    How can I change the home page weather widget on the Galaxy S4 to Weather Bug?
    09-19-2013 12:30 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you installed the Weatherbug app yet? If so, then follow these steps:
    1. Go to your homescreen with the current weather widget, and press and hold it.
    2. When you are able to, drag it to the Remove or trash can icon (this only removes it from the homescreen--it doesn't delete the widget forever).
    3. Now bring up your App Drawer (your entire list of apps). Tap on Widgets at the upper right.
    4. Find the Weatherbug widget, press & hold it, then drag it to your homescreen.
    5. It will probably ask you to configure it first (i.e., location, temperature units, etc.). When you're back on the homescreen, you should see the widget there.
  3. B. Diddy's Avatar
    amrich likes this.
    09-19-2013 01:13 PM
  4. lolo lolla's Avatar
    How do I replacing the weather widget on my Galaxy S4?-screenshot_2014-05-16-23-39-45.jpg
    please the time in widget isn't the same as in the clock and i can't change it !
    05-16-2014 03:59 PM
  1. Any regrets on getting the S4 Active vs the S4 ?
    By OceanView in forum Samsung Galaxy S4 Active
    Last Post: 10-08-2013, 11:05 PM
  2. Replies: 7
    Last Post: 09-25-2013, 07:58 AM
  3. I cant find anwhere whats the pressure senitivity on the note 3?
    By justinsaneeeee in forum Samsung Galaxy Note 3
    Last Post: 09-19-2013, 07:44 PM
  4. Question about battery replacement and sd card
    By clamss in forum Samsung Galaxy S4
    Last Post: 09-19-2013, 12:14 PM
  5. Problem while connecting USB Adapter to Galaxy tab 2 10.1
    By Sourav Sudhi1 in forum Rumored Devices Lounge
    Last Post: 09-19-2013, 11:13 AM
