Hey guys
So I recently got a SGS3 and I'm looking to add to the 16GB internal storage by adding a Micro SD Card. I was aware from other threads - the pinned thread on this site especially - which suggested that 64GB cards are $200 and less. However, by using Google Shopping, I found 64GB SD Cards as cheap as ?7.59 (64GB MICRO SD MEMORY CARD class 10 with a free adapter - UK SELLER! | eBay). As the description says, this is class 10. So my real question is: what is the difference between this cheap 64GB Class 10 Micro SD Card and, for example, a much more expensive SanDisk 64GB Micro SD. Can I expect to see a noticeable difference in performance or is it just expensive branding or something?!
Thanks
Since I'm new to this, please explain anything!
Thanks
