1. brinith's Avatar
    I recently installed the Cyanogen Mod onto my S4 and honestly wasn't impressed with it. How do I uninstall the custom ROM and revert back to the Stock ROM?
    It is the T-Mobile Variant (SGH-M919)
    Can I just restore from a backup before I installed the Cyanogen Mod?
    09-22-2013 09:24 AM
  2. Golfdriver97's Avatar
    Welcome to the forums!
    Did you do a backup in recovery?
    09-22-2013 09:31 AM
  3. brinith's Avatar
    Thanks. Yes I do. Did a backup to my external sd before installing the ROM.
    09-22-2013 09:55 AM
  4. Golfdriver97's Avatar
    Then you simply restore from recovery. Simply as that.
    Sent from a Slim 4.3 S3
    brinith likes this.
    09-22-2013 11:18 AM
  5. brinith's Avatar
    Wow that was surprisingly easy. I guess the fear of bricking has gotten to me.
    09-22-2013 02:57 PM
  6. Golfdriver97's Avatar
    Bricks typically happen when you do something stupid.
    09-22-2013 04:27 PM
  1. Samsung Galaxy Ace won't connect to wifi
    By sneaky cat in forum Samsung Galaxy Ace
    Last Post: 11-01-2013, 03:54 PM
  2. Replies: 7
    Last Post: 10-02-2013, 01:37 PM
  3. Possible to wipe everything and start over?
    By Andrew Fazio1 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 09-23-2013, 07:35 AM
  4. Replies: 2
    Last Post: 09-22-2013, 09:56 AM
  5. How do you stop screen from coming on when you end a call???
    By 44pirate in forum Verizon Samsung Galaxy S4
    Last Post: 09-22-2013, 08:59 AM
