I?ve downloaded the zip file for a custom rom AND the zipped boot.img file.
Question..... I know I need to put the ROM file onto the sd, and install through ??recovery??, and then flash the boot.img with ``fastboot commands``. But do I need to extract the zipped boot.img file or just put it, as it is, into my fastboot folder ?
ROM I intend flashing, and have downloaded is ARHD 8.
Thanks
Thanks
