Results 1 to 4 of 4
    Default [HELP] Backup won't boot up
    I must have done something stupid; I booted up my stock Touchwiz recovery to update it, everything went well so far. After I was done with Touchwiz, I then backed it up with ROM Manager and everything went smoothly with the backup. Afterwards I wanted to get back to my CyanogenMod ROM, I rebooted to recovery, went to backup and restore then clicked the backup which I named CyanogenMod. All seemed well, it was doing its thing with all the numbers and symbols with the Android robot and then it stoped and at the bottom, while still in recovery mode, it read MD5 mismatch. Not sure what to do now, just running laggy TouchWiz until I fix the problem. -_-
  2. Thread Author  Thread Author    #2
    Default Re: [HELP] Backup won't boot up
    Quote Originally Posted by Wahinya Njau View Post
    I must have done something stupid; I booted up my stock Touchwiz recovery to update it, everything went well so far. After I was done with Touchwiz, I then backed it up with ROM Manager and everything went smoothly with the backup. Afterwards I wanted to get back to my CyanogenMod ROM, I rebooted to recovery, went to backup and restore then clicked the backup which I named CyanogenMod. All seemed well, it was doing its thing with all the numbers and symbols with the Android robot and then it stopped and at the bottom, while still in recovery mode, it read MD5 mismatch. Not sure what to do now, just running laggy TouchWiz until I fix the problem. -_-
    Problem was fixed
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,914 Global Posts
    ROM
    Stock Moto X
    Problem was fixed
    Glad it's fixed, but what did you do? Someone else may need to know.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu 'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    STEP 1: Open Terminal Emulator
    Step 2: Use the following commands. (DON'T FORGET TO REPLACE "CyanogenMod" WITH YOUR OWN BACKUP FOLDER NAME)
    su
    # mount -o remount rw /sdcard
    #cd /sdcard/clockworkmod/backup/CyanogenMod
    #rm nandroid.md5
    #md5sum *img > nandroid.md5
    STEP 3: (This will create a new "nandroid.md5" file without ANY "md5 mismatch" errors.)
    Reboot your phone and enter Recovery,
    Restore.
    Thanked by:
  1. Replies: 6
    Last Post: 12-13-2013, 08:55 PM
  2. HELP, Incoming Voice Notifications
    By capnjazz22 in forum Moto X
    Last Post: 09-29-2013, 07:59 AM
  3. Sprint S2 root Help
    By Hvacmanjc in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 09-27-2013, 09:08 PM
  4. Photo Auto Back Up in Gallery
    Last Post: 09-27-2013, 08:10 PM
  5. SMS message with code sent ---- can't locate on G4??? HELP
    By billo14 in forum Samsung Galaxy S4 Google Edition
    Last Post: 09-27-2013, 07:05 PM
B
