Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By dman7895
    dman7895's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help my phone keeps resetting Its self
    My phone will not stay on at all. It will keep restarting unless plugged up to a charger or computer. It will just keep doing that every five seconds I have a galaxy s2 skyrocket
  2. #2
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help my phone keeps resetting Its self
    that's strange. i would make sure everything is backed up and then i would do a factory reset and start from scratch. good luck.
    dman7895's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've done that and it keeps restarting
  4. #4
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dman7895 View Post
    It's worth clarifying if you did an actual factory data reset, or simply a soft reboot.
    Also, consider trying a different battery.
    dman7895's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No apps now and I reset it through the settings
  7. #7
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Sounds pretty messed up. Can you try a different battery?
  8. #8
    cafeblazer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    One thing that could have happened ( if you have perhaps dropped your phone ...) is that the battery is looe and keeps slipping off .. in that case maybe try to put to put a little piece of cardboard on the side to secure the battery so that its real tight ?
  9. #9
    joggy's Avatar
    Posts
    Global Posts
    236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Corrupt SD cards can do this to a phone too...
  10. Thread Author  Thread Author    #10
    dman7895's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks everybody it was the battery I just bought a new one
    B. Diddy likes this.
  1. Nexus Help
    By Jake Serdar in forum Verizon Galaxy Nexus
    Last Post: 12-05-2013, 10:50 PM
  2. What is the exception with my phone?
    By stepaul8 in forum AT&T Samsung Galaxy S4
    Last Post: 10-08-2013, 07:22 PM
  3. HELP! N64oid on T-Mobile Prism II
    By Bladetwist in forum General Help and How To
    Last Post: 10-01-2013, 12:10 AM
  4. Replies: 2
    Last Post: 09-29-2013, 09:01 PM
  5. suspecting my fiance is cheating on me
    By Irinworker in forum Samsung Galaxy S4
    Last Post: 09-29-2013, 07:21 PM
