after the recent update to the twitter app I can't have notifications on vibrate only? unless I turn the volume on the phone to vibrate. I was able to do it before the update? please help.
Welcome to the forums! If the option is no longer available through the Twitter settings then it would appear that it was a feature that was removed. Why that would be is hard to say. You can look at an App called Tasker in the Play Store that allows you to set strict guidelines or actions specific to Apps. That would hopefully help you in the meantime.after the recent update to the twitter app I can't have notifications on vibrate only? unless I turn the volume on the phone to vibrate. I was able to do it before the update? please help.
