Hello guys and greetings from Greece.
I have a chinese MT6577 mobile no name almost a year and I am very pleased. I decided to root with MTK Android and everything went very well.
But I stick to that I can not change my bootloader. I have no option in bootloader to install from sd card.
I installed rom manager, root explorer, super user but nothing I change boutloader with ClockworkMod
Also when the phone is in the home screen of bootloader can not be recognized from windows .
I have used all the drivers for MT65xx usb driver without result. Inside windows the phone recognized without problem.
So my problems.
How can change the stock bootloader Android Recovery 3e with i.e.ClockworkMod
I wonder if the phone in bootloader mode recognized from windows 7 , solve and the above problem.
Thank you for any help.
Hardware : MT6577
Model : GT-I93000
Build number : IMM76D.I93000ZSALED.9P017.6628
Build date UTC : 20121016-085327
Android v : 4.1.1
Baseband v: MAUI.11AMD.W12.22.SP.V8.P2, 2012/08/22 18:19
Kernel v : 3.0.13 (root@wuyue-linux) (gcc version 4.4.3 (GCC) ) #1 SMP Tue Oct 16 16:50:37 CST 2012
So my problems.
Hardware : MT6577
Model : GT-I93000
Android v : 4.1.1
