1. kostas_p's Avatar
    Hello guys and greetings from Greece.
    I have a chinese MT6577 mobile no name almost a year and I am very pleased. I decided to root with MTK Android and everything went very well.
    But I stick to that I can not change my bootloader. I have no option in bootloader to install from sd card.
    I installed rom manager, root explorer, super user but nothing I change boutloader with ClockworkMod
    Also when the phone is in the home screen of bootloader can not be recognized from windows .
    I have used all the drivers for MT65xx usb driver without result. Inside windows the phone recognized without problem.
    So my problems.
    How can change the stock bootloader Android Recovery 3e with i.e.ClockworkMod
    I wonder if the phone in bootloader mode recognized from windows 7 , solve and the above problem.
    Thank you for any help.
    Hardware : MT6577
    Model : GT-I93000
    Build number : IMM76D.I93000ZSALED.9P017.6628
    Build date UTC : 20121016-085327
    Android v : 4.1.1
    Baseband v: MAUI.11AMD.W12.22.SP.V8.P2, 2012/08/22 18:19
    Kernel v : 3.0.13 (root@wuyue-linux) (gcc version 4.4.3 (GCC) ) #1 SMP Tue Oct 16 16:50:37 CST 2012
    10-02-2013 08:00 AM
  2. Golfdriver97's Avatar
    So my problems.
    Hardware : MT6577
    Model : GT-I93000
    Android v : 4.1.1
    Welcome to the forums!
    Try to see if you can download and install updates Samsung drivers for your PC.
    Then you would have to find the file and flash through ODIN.
    10-02-2013 10:34 PM
  1. Replies: 1
    Last Post: 10-02-2013, 09:22 AM
  2. Android work like Windows
    By pnperl in forum General Help and How To
    Last Post: 10-02-2013, 08:30 AM
  3. [FREE] EBook Reader Android Application - Smart Reader
    By wenddypaull in forum Android Apps
    Last Post: 10-02-2013, 06:19 AM
