Results 1 to 9 of 9
    surfol's Avatar
    Posts
    Global Posts
    15 Global Posts
    Default Slight Delay/Lag Opening Contacts and Dialer in Note 3
    Hey guys,
    I notice a slight delay opening Contacts (3+ seconds) and Dialer (1+ seconds) in my Note 3.
    This happens when opening them for the first time. After they've been opened once, opening them the second time is instant.
    However, this happens again after I clear all the running apps and opening the Contacts and Dialer again (I clear them using the stock task manager, press and hold Home button).
    I'm not sure if it happens right after unboxing (I didn't really pay attention to this at the time).
    But it could also happen after I turn off and uninstall updates on some of the bloatwares,
    or after I install the update to the bug in Keyboard from Samsung, though I'm not sure.
    Specs:
    -Note 3 Exynos, Stock Samsung (no firmware update yet)
    -No New apps installed at all, just some updates to the bloatware and Keyboard Update from Samsung
    -800+ contacts, all google and synced together with gmail
    -The 3 settings in Development Mode (The animator, transition etc) are set to OFF
    -S Voice is removed from the Home Button
    Does anyone experience the same problem? and is there a fix to it? I've already done a research in the forum and some of you seem to have the same problem (though not on Note 3), but I can't find any real fix.
    Thanks!
  2. #2
    Default Re: Slight Delay/Lag Opening Contacts and Dialer in Note 3
    Welcome to Android Central! When you say it happens again after you clear running apps, do you mean that you're using a task killer? If so, I would advise against it. Starting an app up from scratch can take noticeably longer than if it is already active or cached in system RAM, and it will also take up more battery as well, since it requires more CPU power to start things up. The Dialer and Contacts app are so essential to the phone function that they really should never be closed.
    If you're new to Android and how system RAM works and how apps are handled, please read this excellent article by Jerry Hildenbrand: RAM: What it is, how it's used, and why you shouldn't care | Android Central
    surfol likes this.
    surfol's Avatar
    Posts
    Global Posts
    15 Global Posts
    Quote Originally Posted by B. Diddy View Post
    Hello, thanks for the reply and article. I didn't use any 3rd party task killer, just the press and hold Home button .
    Still looking for a fix
  4. #4
    Do you mean you brought up the Recent Apps list and swiped all of the apps away?
    surfol's Avatar
    Posts
    Global Posts
    15 Global Posts
    Yes, that's correct.
    If I do that, the next time I open it, there'll be a delay of 3 seconds+.
    I think that an Octa core high-end smartphone should be able to open a small app like Contacts instantly even though it's not already cached in the RAM.
    Opening a gmail that's not already cached in the RAM is actually even faster (1 second max)
    I was wondering if there's a fix to this, or is this a common and accepted issue in Android/Samsung smartphones?
    If yes, are there any recommended Contacts and Dialer apps/launcher that are fast?
    surfol's Avatar
    Posts
    Global Posts
    15 Global Posts
    Solved. It turned out that my issue was caused by turning off Chat ON app.
    I actually turned the Chat On off when I first got the phone, and now I tried to turn it back ON.
    The lag has now been reduced to 1-1.5 seconds after turning the Chat On app back ON.
    If the contact has not been closed from the task manager, it's instant.
    So this is much more acceptable now.
    Hope this helps others with the same issue.
    B. Diddy likes this.
  7. #7
    Hey anyone find a solution to this? I have 9300 contacts and it is always really delayed when I open my contacts.
  8. #8
    I have also same problem, I will try the suggested option.
  9. #9
    Hey guys,
    I know this an a very old post, but I'm looking for solutions to this exact problem that started with my s6 after a samsung software update last week.
    Dialer, messages and Contacts take 5 seconds or so to open (if not open recently). This is happening on 2 s6's that I know of and only since a samsung update.
    This is my first post, so if anyone has any ideas I would be very grateful.
    Thanks!!
    Tim 😊
  1. Note 10.1 - 2014 manual?
    By KiltedMP in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-12-2013, 09:02 PM
  2. Are custom contact ringtones new on the S3?
    By drmaf894c in forum Verizon Galaxy S3
    Last Post: 10-05-2013, 07:53 AM
  3. Replies: 7
    Last Post: 10-03-2013, 08:00 PM
  4. transfer all info from S4 to Note 3
    By gumbyr1 in forum Samsung Galaxy Note 3
    Last Post: 10-03-2013, 11:52 AM
