Been looking for this for the better part of a year, so, starting a new thread for others on the same quest.
While android voice recognition is good, it is poorly documented, and the (apparent) absence of any way to input "newline" via voice has been frustrating. Turns out, it's possible, but it can be "iffy"
"Newline" works following a "period" For example,
Hello period newline
"New Paragraph" works and adds two carriage returns without needing a leading period ...but not all the time.
Most punctuation works... period, comma, question mark, semicolon, colon, and I assume others, are there, but see below.
All of the above seem to rely on the adaptive recognition. All of the above was working well until I began tinkering with the input settings and downloaded the "offline dictionary" Hopefully, time will bring the learning back.
Hope that this information is of value.
Beverly Howard
Beverly Howard
