Results 1 to 20 of 20
Like Tree5Likes
  • 1 Post By UJ95x
  • 1 Post By B. Diddy
  • 2 Post By EvilMonkey
  • 1 Post By lloydloft
    lloydloft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I hate this heap of junk
    Hi everyone.
    This is my first post on any forum anywhere so it's a shame it's done in such anger. So please excuse my temper or possibly completely noob and numpty question / problem.
    I have a Samsung Galaxy tab 2 10.1 (p5110) which has just been updated to 4.2.2 and I @#$%^&* hate it!
    All Google tabs close when I go to home screen and back. Even if I open a new tab and go to bookmarks, all other open tabs are gone.
    No apps remain 'active' when I go away from them and always reset.
    And it's SLOW!
    I also don't like the way I can't save 'show desktop' setting.
    The version I had before (whatever that was) worked a treat and I'm very close to throwing this heap of junk in the bin and getting an ipad. (Of course the problem with that is my iphone has just been updated and I hate that too)
    I thought updates were supposed to improve things, not make them harder to use!
    Are my problems common, unique to me or are they not problems at all and I'm just stupid?
    Am I missing some settings somewhere?
    Can it be fixed?
    Can I reinstall the previous version?
    Should I throw it in the bin?
    I was thinking about swapping my iphone over to an Android but I doubt that is going to happen now.
    Can anyone help with any advice or solutions. Please?!
    Remember - I'm a numpty with this stuff!
    Thanks.
    And sorry for the rant!
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: I hate this heap of junk
    Quote Originally Posted by lloydloft View Post
    Hi everyone.
    And it's SLOW!
    Can it be fixed?
    Thanks.
    First off, welcome to Android Central.
    About the version, you should be able to go back to the previous version if you factory reset it. This will delete everything on the device (not what's on the SD card but I'd take it out if you have one inside) so I would recommend you back up your data before doing so.
    srkmagnus likes this.
  3. #3
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to Android Central, and yikes, sorry you're so frustrated! One thing to try is a system cache partition wipe, which can clear away some of the old temporary system data that can potentially cause problems, especially after a system update. Follow these instructions to get to the Recovery menu, but instead of "Wipe Data," make sure you select "Wipe Cache Partition." You won't lose any personal data.
    Golfdriver97 likes this.
  4. #4
    EvilMonkey's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ouch. I agree with B. Diddy here....try wiping the cache partition. You might be dealing with some leftover things from the update that's causing some havok.
    B. Diddy and Golfdriver97 like this.
  5. #5
    kernmal's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by UJ95x View Post
    A Factory Reset will not roll back a system update.
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Welcome! Sorry to hear about the bad experience the Tab is giving you - hopefully it doesn't leave a sour taste for you and future Android devices.
    Try the above suggestions and let us know how things go.
    Sent from my SPH-D710 using Tapatalk 2
  7. #7
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by kernmal View Post
    Really? I thought it would
  8. #8
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    The times I have done a factory reset on my RAZR Maxx, the OS did not roll back.
  9. #9
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,092 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Every factory reset I have done has no bearing on the OS version. Resets clear apps and settings.
    From a Sprint Moto X using AC forums app
  10. #10
    Posts
    Global Posts
    33,092 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Hi everyone.
    And it's SLOW!
    Can it be fixed?
    Thanks.
    A cache wipe my help out a lot. Give that a try and let us know what happens.
  11. Thread Author  Thread Author    #11
    lloydloft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks heaps for the replies everyone, I really appreciate it.
    Today is a new day and I've taken a deep breath. I just got home from work and got myself a beer and I'm ready to tackle your suggestions.
    I did think about a factory reset at first but was a bit worried about starting all over again so wondered if there was a better / easier solution.
    I will have a go at 'wipe cache partition' and let you know how I go.
    I am but a mere wood machinist!!!
    Thanks again.
    B. Diddy likes this.
  12. #12
    Distant Deviant's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I didnt read your post but..
  13. #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Fail
  14. Thread Author  Thread Author    #14
    lloydloft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, its still a heap of junk!
    it wont even let me wipe cache partition.
    It says 'no command' then starts to erase briefly before saying 'error' then rebooting.
    I havent tried a full hard reset yet incase I stuff it competely.
    I tried finding out what 'no command' means before I bothered you good folk again but I found nothing.
    anyone have any ideas?
  15. #15
    stalemate1's Avatar
    Posts
    Global Posts
    967 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Another disadvantage to rooting...
    What device is it ?
    Sent from my HTC EVO 3D X515m using Mobile Nations mobile app
  16. #16
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by stalemate1 View Post
    What device is it ?
    It's a Galaxy Tab 2 10.1, and the OP never mentioned rooting.
  17. #17
    stalemate1's Avatar
    Posts
    Global Posts
    967 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    To have that many issues I can only guess he's rooted.
  18. #18
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default
    Interesting point. If the OP never rooted, it'd be important to know where the tablet came from, because if it was used, maybe it came already rooted without his knowledge. Any comment, lloydloft?
  19. Thread Author  Thread Author    #19
    lloydloft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not rooted (wouldnt know how)
    Bought it new about 6 months ago.
    Did I get a dud?
  20. #20
    stalemate1's Avatar
    Posts
    Global Posts
    967 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did I get a dud?
    Did you try a battery pull ? (Take battery & sim card out device for 10 minutes and put back in)
    Did you try a factory reset ?
    ( I also at one stage had major problems with my device-stock apps such as settings crashing every time I open settings with sense re loading often when I close an app and go to home screen. I did a factory reset and discovered that avast agent was the cause to all my issues-phones fine now)
  1. Note 3-Sprint-Green Bay, WI (and the surprise appearance of 4G)
    By PastorDroid in forum Sprint Samsung Galaxy Note 3
    Last Post: 10-15-2013, 10:21 PM
  2. Replies: 7
    Last Post: 10-08-2013, 05:19 PM
  3. Underrated feature of the Note 3
    By zach_alt in forum Samsung Galaxy Note 3
    Last Post: 10-07-2013, 03:00 PM
  4. been stuck on this problem for hours :( can anyone help
    By Randy Janjua in forum General News & Discussion
    Last Post: 10-07-2013, 12:00 PM
  5. Verizon galaxy note 3 in best buy on the release date of 10/10
    By Nicole Simmons in forum Samsung Galaxy Note 3
    Last Post: 10-05-2013, 11:41 PM
