1. Firefly333's Avatar
    I have been searching for an answer to this since I got the phone about 2 weeks ago.
    The phone begins to ring and will ring for maybe a second, the screen lights up for me to answer, then it goes back to home screen and ring stops. A missed call notification shows up and then immediately begins to ring again...this only takes maybe a second... it does this over and over, showing up to 12 missed calls for one call. I have tried factory ringtones and downloaded, it does not discriminate.
    If the same person calls right back and I am able to answer, I ask how many times did you just call and they will say - just once -
    Its not a service issue and its been happening from the day I got the phone.
    Most times I can answer after the 2nd or 3rd attempt of the person calling and sometimes it doesnt act up for a day.
    I am at my wits end as tonight I have been trying to answer a call for several hours and am unable to. I do not know any lingo or have an understanding of fancy fixes, but if anyone has an idea I sure would appreciate it.
    10-16-2013 11:45 PM
  2. Firefly333's Avatar
    I did a factory reset this morning. First call rang through as 6 missed calls - same as above. They called right back and I was able to answer. Any insight would be so helpful as the reset did nothing to help.
    Thanks so much!
    10-17-2013 09:23 AM
  1. Garbled voice calls - Verizon says they can't fix
    By slide83 in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-10-2015, 12:35 AM
  2. Phenomenal Headphones for $10
    By RoccOn16v in forum Headsets
    Last Post: 02-08-2014, 11:46 AM
  3. Galaxy s3 black screen
    By Jacob Perales in forum T-Mobile Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-11-2013, 10:53 PM
  4. love samsung
    By androidfanz in forum Samsung Galaxy S4
    Last Post: 10-21-2013, 03:49 PM
  5. Replies: 3
    Last Post: 10-17-2013, 07:35 AM
