I am about to go get either the Note 3 or the LG G2, coming from a S3 then an S4 (S4 got stolen, and I kinda rather just upgrade, it was barely better then my S3, which I love that phone) ANYWAYS, I was wondering if there would be any problems with doing this. I hooked my buddy up on my plan like 2 weeks ago and gave him my old LG Revolution, which has Gingervolt and some other mods. We had to go to our local Verizon store to get a new SIM card and have them activate it, but not only did it cost me nothing to do this, they never said a word about it. So I should be good right ?
Also, as I said, I cant seem to decided on a Note 3 or an LG2. Need some opinions. I like a lot of what each one does. But I do like the Note's bigger screen, 3GB of RAM, 2.3Ghz Quad-Core, etfc etc, sure you guys know the specs. So I am leaning towards it, but I like the on screen buttons of the LG and the Camera is supposedly better, It has a 2.3Ghz CPU as well if I Believe. Going down there in like an hour, two tops, so any helpful replies would be appreciated. Thank you
