Results 1 to 3 of 3
    ngoody315's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How To Stop Roaming Data
    So I just recently moved to China and I had my phone unlocked from my AT&T carrier in the states to the local carrier China Mobile. I put in the new SIM card and went to Apps>Settings>Mobile Networks>Data Roaming and made sure it was unchecked. But there is still a Roaming icon on the top of my phone and it says that Roaming is Enabled when it's not. I even went as far as turning Mobile Data off completely and it still shows me Roaming. How to I get this to go away and avoid charges?
  2. #2
    Mooncatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How To Stop Roaming Data
    That signal means roaming in general, be it data or for calling. Since you went so far as shutting data off, it means you're apparently roaming if you make calls. I'd check with the Chinese carrier and see what your exact coverage area should be or if your plan allows any roaming at no charge. I'm not familiar with how their services operate.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,091 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    You could try turning on airplane mode, then turning on WiFi.
    From a Sprint Moto X using AC forums app
  1. How can I update to JB 4.3 ?
    By Rab3awy in forum Samsung Galaxy Grand
    Last Post: 01-13-2015, 04:22 AM
  2. HTC One - Speech to text feature missing
    By ardnaszavi in forum HTC One M7
    Last Post: 01-01-2015, 08:20 AM
  3. Replies: 5
    Last Post: 10-25-2013, 11:46 PM
  4. HTC One must be a good phone if Samsung is paying to bash them.
    By buzzyclonecattleman in forum HTC One M7
    Last Post: 10-25-2013, 10:40 PM
  5. Replies: 1
    Last Post: 10-25-2013, 07:43 PM
