1. Goldeneagle72's Avatar
    Custom Rom Builders of Galaxy Rush
    Present to you:
    KitKat Explosion Rom v2.0
    I want to give a big thanks to kRize, AlexRayquaza, and Lordvincent90 for their help, they are the dreamteam that's putting the magic together, thanks so much guys...
    JellyBean 4.1.2 with 4.4 added apps!!
    This is Stock Modded & Themed
    What's in it?
    **NEW** 4.4 Google Home Launcher with Google Now integrated
    **NEW** 4.4 Google Desk Clock
    **NEW** 4.4 Google keyboard
    Google chrome
    **NEW** 4.4 Gmail
    Google sound widget
    Google games
    **NEW** 4.4 Google calendar
    **NEW** Google+
    **NEW** Photos
    Google settings
    **NEW** Updated Google Play Store 4.4.22 with Clear Theme
    Supersu
    **NEW** Hangouts 2.0
    Also calculator
    Samsung Camera
    Samsung Gallery
    Samsung video player
    Es File Explorer
    Quick settings
    Downloads
    Stock dialer
    Stock contacts
    Stock messaging removed (Hangouts' SMS feature replaces it)
    Ubuntu font
    WiFi tether
    Xposed app settings
    Xposed extras
    Xposed installer
    Xposed xtheme engine
    Xposed tweakbox
    Xposed AOSP Lockscreen (Thanks to Zenwafer for suggestion)
    Viper Fx
    Viper xhifi
    Youtube
    New additions for Settings Menu (Special thanks to LV90)
    Boot sound enabled with new boot sound (Special thanks to superboy4444 @Reverb Forum)
    Custom Bootanimation
    Everything with Xposed is at latest version
    **NEW** Externalsd2Internalsd Mod
    :smokingsomb:
    Power menu (thanks to bloodawn)
    Centered clock
    10 toggle notifications
    **NEW** System notification, ringtone, alarm sounds, and ui sounds from KitKat
    Themed framework (wip)
    SCREENSHOTS:
    DOWNLOAD LINK:
    KitKat Explosion 2.0_FIXED
    My Developer Forum for continued support for our Samsung Galaxy Rush:
    Custom Rom Builders of Galaxy Rush - Android Forums
    This is a WIP so if you guys have any questions or something that you need help with don't hesitate to ask and thanks for checking the rom out!!
    What people are saying about KKE v2.0:
    I just want to thank all of you for the work that you've put in. I finally feel like this phone is at it's full potential, and I just cashed in my last replacement phone at Best Buy. Now just to buy a new case and an extra battery. Gonna try to make this phone last a few years.
    Wi-Fi tethering works! GPS works! It all works! WHOOOOOOOOO
    This looks awesome I can't wait to tinker with this baby. Love all the work you guys put in to this phone. Big BIG THANKS!! YOU GUYS ROCK!
    I haven't tried any of the roms since we got JB but I think this will be the one looks great good job all
    Thanks guys, btw I love how this rom installs. Its like going from the DOS days into the Windows days. If you know what I mean.
    Xposed themes found here:
    [XTHEME][TW][PORT] alphaBlueX | Mixer | SimpleX | SimpleX_Blue | AlloyX | - xda-developers
    Thanks to Pier10
    Setting up WiFi tether:
    Device Profile: Generic ics/jb wlan0
    Setup method: Auto
    Send netd max client cmd: checked
    WiFi driver reload: checked
    WiFi driver reload 2: no check
    Routing fix: checked
    Also make sure your keep WiFi on during sleep is set to never: settings/WiFi/menu/advanced/keep WiFi on
    You can also turn off auto WiFi on/connection manager:
    Settings/more/mobile networks/connection optimizer
    Setting up Xposed module:
    Open closed installer and press install/update then soft reboot.
    Go back to exposed installer and press modules, and place a check on each box, then soft reboot.
    Go to closed apps and make you modifications then reboot for your settings to stick.
    How to install Viper:
    Open viper fx and xhifi and choose CortexA8 with NEON
    The other settings are up to you. For more info check here: [APP] ViPER4Android Audio Effects (FX 2211-1 & XHIFI 2102-1) - 20/9 Review on XDA TV - xda-developers
    I would like to thank K Rize, LordVincent90, Zenwafer, AlexRayquaza, pyro_guy0001, and kskillz2000 for there helping hand, and hard work, I really appreciate each and every one of you that help to make this rom what it is, PURE GENIUS!!
    sgolden6810 and Golfdriver97 like this.
    10-28-2013 06:07 AM
  2. Goldeneagle72's Avatar
    Hello everyone, this is my Rom for the Samsung Galaxy Rush, this post will be moved to the Samsung Galaxy Rush section once it's created, thanks to all who check my Rom out, have fun!!
    10-28-2013 06:31 AM
  3. Mr Cante's Avatar
    So I did all the steps and now my phone doesnt work...
    11-19-2013 05:45 PM
  4. jdub81's Avatar
    Down loaded and installed works great but not every thing listed in the ROM showed up on the phone. Google chrome was not there and other things any ideas or help. thank you
    12-13-2013 09:45 PM
  5. Ganozanator's Avatar
    Hey I Installed the ROM. Works Great! Does it also prevent throttling?
    12-17-2013 09:58 AM
  6. Rukbat's Avatar
    Necroposting, but since throttling is done by the carrier, no ROM can prevent it.
    01-05-2014 11:22 PM
  7. Eric Page1's Avatar
    google chrome waS NOT LISTED. SIMPLY DOWNLOAD AND INSTALL THE APP HAPPY BROWSING
    SORRY ITS THERE JUST TURN IT ON
    01-18-2014 08:08 AM
  8. Sean Reece's Avatar
    Love this rom, but I have one question... is there a way to disable the music on startup? My phone has a tendency to reboot itself from time to time in my pocket and if it rings I can silence it but if its rebooting I have to listen to that stupid song or take the battery out... especially frustrating if I'm trying to silence it quickly.
    02-12-2014 01:21 PM
  9. ViosX's Avatar
    Hi,
    i had issues installing but i figured out that was b/c i didn't have enough space on the sd card for temp files so the phone would just reboot during install (10%). i second the user above's comment about the music , i mean i like vinnie paz but if i was making a rom i wouldnt assume every1 would like the song i picked and would just leave it out. also im having trouble changing the theme , but im just learning about the framework apps and stuff. any easy way for us to change the startup song other than that this ROM RUNS GREAT so far, setcpu is crashing but i dont think its installed yet !!!!
    07-23-2014 12:39 AM
  10. victor moreno3's Avatar
    hello, thanks for the custom pack, and install it and it works great, but I have a problem, I want to change the background image when an application is started, it is a picture with white background and a blue face with many teeth. Thank you for your help
    10-20-2014 08:10 AM
  1. Replies: 16
    Last Post: 01-31-2015, 04:34 AM
  2. Galaxy S2 would only go to opening screen and now wont turn on at all.
    By Jamie4400 in forum General Help and How To
    Last Post: 10-28-2013, 12:17 PM
  3. [FREE] Crafting Ideas For Minecraft :3
    By luk4sproductions in forum Android Apps
    Last Post: 10-28-2013, 05:13 AM
  4. Samsung Galaxy S4 Android 4.3 Update
    By Dean Cull in forum Samsung Galaxy S4
    Last Post: 10-28-2013, 03:07 AM
