1. Noel Mendoza's Avatar
    Hello Good Evening Im From PH
    My problem is, i stack in Android Boot Logo and i can't access anything in my Android..
    i think it got hanged..
    please help me..
    The story is: i installed AWD LAuncher EX. and Set a new themes for my phone, and freezes my default Launcher by: TitaniumBackUp. then i reboot it , and i got my problem..please help..srry for my bad english,,
    10-28-2013 10:22 AM
  2. Golfdriver97's Avatar
    please help me..
    Welcome to the forums.
    Which device?
    10-28-2013 10:31 AM
  3. Noel Mendoza's Avatar
    StarMobile HIT... 2.3.6 Gingerbread sir
    10-28-2013 10:39 AM
  4. Noel Mendoza's Avatar
    Which device?
    i hope you can help me sir.. do you have facebook?
    10-28-2013 10:41 AM
  5. Golfdriver97's Avatar
    I am not familiar with that device...can you reboot into recovery?
    From a Sprint Moto X using AC forums app
    10-28-2013 10:43 AM
  6. Noel Mendoza's Avatar
    ..can you give a full tutorial sir
    because, every time i turn on my Phone, i get stack in Boot logo " Android" and nothing happens...
    and eery time i put my USB Cabe Phone to Computer, nothing happens to but it make sound that my device is detected....
    10-28-2013 10:47 AM
  7. Golfdriver97's Avatar
    Power off, then press and hold volume up and power until you see the Manufacturer logo, then release. You should see a menu. Scroll down to wipe cache partition. Hit power to select. Top of the menu is reboot device. Power to select.
    10-28-2013 10:54 AM
  8. Noel Mendoza's Avatar
    nothing happen ..
    what should i do
    10-28-2013 10:59 AM
  9. Golfdriver97's Avatar
    nothing happen ..
    what should i do
    Now I am not so sure. Can you remove the battery for a few minutes?
    10-28-2013 11:12 AM
  10. Noel Mendoza's Avatar
    Same
    i don't know what to do
    i have to get rid of the Launcher and Unfreeze my default launcher
    10-28-2013 11:35 AM
  11. Golfdriver97's Avatar
    Same
    Were you able to get into the recovery menu?
    10-28-2013 11:41 AM
  12. iamRICASISON's Avatar
    Same as mine. My fone also hangs ( STARMOBILE MUSE) I rooted it after i changed my font it reboot and stock on android logo. Dont know how to fix.!! Help.
    06-09-2014 10:52 PM
  13. Regino Petilla's Avatar
    You can use ADB (Android Debug Bridge) to "replace" the font you installed that caused bootloop. If you enabled the usb debugging mode in developer option, there's a big chance that you can fix your phone. Make sure that your device can be detected by computer. Google for more details about ADB. Thanks.
    07-06-2014 09:28 PM
  1. Replies: 0
    Last Post: 10-27-2013, 06:48 PM
  2. Replies: 2
    Last Post: 10-27-2013, 12:23 AM
  3. Galaxy S3 SGH-T999 Stuck in BOOT RECOVERY MODE
    By DataratN2 in forum T-Mobile Galaxy S III
    Last Post: 10-25-2013, 06:15 AM
  4. Replies: 1
    Last Post: 10-23-2013, 11:04 AM
