I recently got a Sansui LifePad 7" WiFi-only tablet (ETAB701). The problem is that there are 2 storage solutions: the +-500MB of internal storage, and the +-1.5GB of "SD Card". The problem is that I was doing fine with it, until I ran out of storage in my 'Internal Storage' section. I went into the Apps section in Settings, and saw that, for only SOME apps, I could tap "Move to SD card". This managed to bring down my levels again, but now I am faced with the same problem. All of my apps that can go to the SD card are there, and now I have no space left for the other apps that can't go to the SD card. The strangest thing is that I can put a MicroSD card into my tablet AND there already seems to be an SD card inside it that, as I said before, cannot be used fully. Does anyone know how I can make my other apps go to this built-in SD card? My tablet runs Android 4.0 ICS. Thanks for any help!
