10-10-2016 06:47 AM
38 12
tools
  1. ralf23446's Avatar
    I was tinkering around before activating the phone. Aparently I have a 'me' in my contacts I guess is shown to other android users in addition to what they have my # saved as. I aparently entered jumbled letters for this and can't delete or edit it. I also have a few other contacts I made while tinkering that don't have phone numbers. There seems to be no way to delete or edit the 'me' or the contacts with no #s or even the contacts with #s. Except for adding a photo.
    I tried everything I could think of, pressing and holding down the names and everything and sliding, etc etc in the 'people' app and when pressing the phone icon which bring up different screens. The names in my 'people' that don't have a # saved don't show up when I click the phone icon to dial, but that's besides the point.
    11-01-2013 02:20 PM
  2. mrsmumbles's Avatar
    I think you just open it and press the menu key (3 lines or dots) for options (edit, delete, etc.).
    Sent from my LG870 via Tapatalk 2
    11-01-2013 03:21 PM
  3. srkmagnus's Avatar
    Yes, to edit a contact you need to press menu then select edit. From there you should be able to delete the contact.
    mrsmumbles likes this.
    11-01-2013 03:41 PM
  4. ralf23446's Avatar
    Forgot to mention this is a jelly bean ZTE AWE.
    Now that the phone's activated, I can hold down pressed on the number and 'edit it before calling' , but I still can't figure out how to edit the name or just delete the contact.
    The 'me' jumbled letters is gone now that I activated the phone and are replaced with my #.
    All the contacts I saved when the phone wasn't activated are gone now that the phone's activated and it did a factory reset all settings.
    11-01-2013 10:48 PM
  5. B. Diddy's Avatar
    If you want to edit contacts, you need to do it from the Contacts or People app. It sounds like you're trying to edit from the Dialer/Phone app, which generally doesn't have an edit function.
    Jonah Jones1 likes this.
    11-02-2013 09:30 AM
  6. jaime1822's Avatar
    Tap on the person that needs edited. There should be a pencil looking icon in the upper right corner. You can edit anything in the contact from there.
    11-02-2013 10:00 AM
  7. ralf23446's Avatar
    lol, no, there's only a star there to add to favs.
    Do I need a seperate app for this or something?
    11-02-2013 04:22 PM
  8. B. Diddy's Avatar
    If you are in the Contacts or People app, select the contact, then press the Menu button. You should see options to Edit or Delete. As mentioned above, make sure you're in the Contacts app, not the Phone Dialer.
    11-02-2013 06:12 PM
  9. liddellw1's Avatar
    To delete a contact simply press and hold on the contact you wish to delete and a menu will pop up that allows you to delete.
    11-02-2013 06:47 PM
  10. ralf23446's Avatar
    lol, that doesn't work. By default (because I haven't made a google account to get more apps). I only have a People app, nothing titled Contacts. I go to the people one which lists my contacts and tried everything. I'm not really worried about it now, but it's baffling.
    11-03-2013 09:43 PM
  11. B. Diddy's Avatar
    I'd still like to get to the bottom of this, though. The People app is the stock Google contacts app (I only mentioned a Contacts app in case it was called something different on your device--it can differ depending on the device manufacturer). With the People app, tell us: what do you see when you select a contact and then tap the Menu button (either the hard menu button or the 3 vertical dots menu button on the screen)? Do you see any Delete option at all?
    11-04-2013 08:35 AM
  12. jaime1822's Avatar
    Is there anyway you can upload a screenshot, with name and number blacked out of course, so we can see what you are seeing?
    Posted via Android Central App on my Big Red LG G2
    11-04-2013 02:52 PM
  13. ralf23446's Avatar
    sorry such big photos.
    First I click the icon on the bottom of the person with no nose or eyes (the phone icon gives me even less options).
    Then it shows all my contacts. I clicked the one I named 'Test' w/ Phone # 555-555-5555.
    I think I tried everything but can't edit the name/number/delete it.
    I checked through all my stock app - The closest thing I have to edit/delete contacts I'm thinking is the People app (which is what these pictures are from).
    So, do I need to DL an app or something to edit/delete contacts?
    11-07-2013 09:26 PM
  14. ralf23446's Avatar
    bump. thanks.
    11-10-2013 12:45 AM
  15. B. Diddy's Avatar
    Are any of those screenshots from pressing the main menu button (either a hard menu button on the phone or a soft menu button in the lower or upper margins, looking like 3 vertical dots)? The 3rd screenshot looks like you long-pressed the face, which is just prompting you to add a picture for your contact. The 4th screenshot looks like you just long-pressed the phone number. There should be a separate menu button--it would help if the 1st screenshot showed the whole screen, since the menu button may be at the bottom of the screen. If your phone has a hard menu button, try pressing that.
    11-10-2013 01:03 AM
  16. Rukbat's Avatar
    You're tapping (pressing for about a second or less?) the name of the contact, right? Long-press it (hold it down for about 3 seconds). When you let go, a menu will pop up. Delete should be down at the bottom of that menu (you'll have to scroll down). Tap Delete and the contact will be gone. (I don't remember if it asks you if you're sure you want to delete it.)
    BTW, that second icon at the bottom of the home screen, the blue/white one with the face, is your "contacts".
    11-11-2013 06:53 PM
  17. ralf23446's Avatar
    Open you're contacts/people app, tap on the contact in the list you want to edit, and then somewhere on the screen will be a pencil icon,... tap that and you will be able to edit all fields.
    My screen shot is from my "Me" contact entry in Android 4.1.2. Jelly Bean.
    The second photo I uploaded is what you're saying should show the pencil icon, but it's not there (eventhough the bottom section of the screen shot isn't shown).
    "You're tapping (pressing for about a second or less?) the name of the contact, right? Long-press it (hold it down for about 3 seconds). When you let go, a menu will pop up."
    Both methods bring up the same menu which is the second screen shot I posted.
    I'm begining to think I got a defected /buggy phone or something. I got it right after it was released. I updated all the options in system updates (PRL, Profile ZTE software etc), but it's the same. I contacted virgin mobile and linked this thread to see what they say about this and possibly a warranty replacement phone.
    All I can do is shown in the photos (add photo per contact, copy # to clipboard etc).
    11-13-2013 06:35 PM
  18. B. Diddy's Avatar
    You still haven't mentioned what happens if you press the phone's capacitative Menu button when you're on the contact's screen.
    11-14-2013 03:14 AM
  19. ralf23446's Avatar
    There's no three verticle dots anywhere. All I access is show in photos. The only place I see 3 verticle dots is when I enter the app/whatever to make a phone call by pressing the icon that looks like a phone, but those 3 dots lead me to phone settings of no help.
    I think I have a buggy phone. Virgin Mobile was basically no help. There seems to be major menus missing. I also can't edit how much the screen lock prevents but read that it can be altered (I want to block incoming calls and showing the #, but w/ screen locked, I can answer calls and read the contact info despite screenlock is aparently easily cracked). With the latest/2nd latest Android version jellybean, I would think this is standard and not left out since my phone was cheap like $99 when I got it.
    Because of a sort of radiation phobia and I barely use the thing, I actually opted to get this 3G phone instead of spending just like $40 more for a 4G lte phone with much better CPU and ram etc. But if I can't figure out how to fix these problems or get it replaced under warranty, I guess I'll sell it used and get the 4GLTE one.
    11-14-2013 09:41 PM
  20. sanchitgrover's Avatar
    Did long press give anything ? Option to edit ?
    Download a third party contact application from playstore
    11-14-2013 10:05 PM
  21. B. Diddy's Avatar
    According to reviews I looked up on the web, the ZTE Awe should have 3 capacitative buttons for Back, Home, and Menu just below the lower edge of the screen--I can see them in that first picture you posted. The Menu button is the one on the right. That's the Menu button you should try pressing to see if anything comes up. If a device has capacitative buttons, the software usually knows not to include a 3 vertical dot soft menu button.
    cw1562 likes this.
    11-14-2013 10:23 PM
  22. ralf23446's Avatar
    ^ bingo, the button on the phone (not the screen) that I aparently never knew existed does it. Thanks.
    But I still can't figure out how to lock the screen and not allow it to answer incomings and show who's calling. I think texts might display also when it's locked which I don't want.
    B. Diddy and cw1562 like this.
    11-15-2013 02:25 PM
  23. B. Diddy's Avatar
    Glad you found the menu button, but now I'm not entirely sure what you mean about locking the screen. You can select your screen timeout (i.e., how long before the screen shuts off if the phone is idle) under Settings/Display, and you can select how long to wait after the screen shuts off before the phone requires the unlock PIN or pattern under Settings/Lock Screen. There's also an option there to make the Power button instantly lock the phone.
    Now, when the screen is locked, you say you don't want to "allow it to answer incomings"--are you saying you don't want it to ring and only show caller ID? It should always show a caller ID when ringing.
    11-15-2013 03:12 PM
  24. ralf23446's Avatar
    Yeah, I know the first paragraph ^
    My old phone (borderline not a smart phone) didn't show who was calling when it was locked and I want this one like that. I did some googling and some phones can change how much is shown when the phone's locked. I can even answer the call when the phone is locked but don't see a settings options to change this.
    It'd be nice to call the phone if it's locked and lost then found and if the person who found it is nice (although they could probably mail it to the branded service provider then be reimbursed for postage and I should end up with the phone eventually, plus there are tracking apps), but, maybe there's an app that can block iincoming calls and caller id when locked. it's not a big deal if no one knows a quick solution, I'll probably eventualyl figure it out if it's possible.
    11-15-2013 09:01 PM
  25. B. Diddy's Avatar
    That's a tough one--I don't think I have an answer for that. Good luck!
    11-15-2013 10:06 PM
38 12
  1. what does My Places do?
    By icnmayhem in forum Samsung Galaxy Note 3
    Last Post: 04-13-2016, 08:31 PM
  2. Hangouts Contacts
    By MaccaBird in forum Samsung Galaxy S4
    Last Post: 11-20-2014, 12:41 PM
  3. how much battery life do you get on your G2 ?
    By stalemate1 in forum LG G2
    Last Post: 06-20-2014, 09:11 AM
  4. ok, how do you select text on the htc one?
    By Troneas in forum HTC One M7
    Last Post: 11-01-2013, 02:08 PM
  5. Deleted screenshots
    By charlibob in forum Samsung Galaxy S4
    Last Post: 11-01-2013, 02:00 PM
