Hi, Might sound a silly question but is there any easy way to answer a call?
I just got my first android (4.2) phone and find it a complicated procedure to answer calls.
When I get an incoming call I get a white phone symbol which I have to press and hold to get the red and green phone symbols to appear and to answer a call the timing has to be exact as if I release the white phone symbol before I have started the slide to answer it fails and I find it about impossible to reject a call with this method.
I thought there might be some setting to alter this like the lock screen but can't find anything.
