1. David Santos2's Avatar
    Will I lose apps and data of the apps if I root? [Galaxy Tab 10.1 3G running 4.0.4] please reply and can you recommend an app [doesn't matter if it requires a computer as long it works with my tab 10.1] that can backup my apps and data?
    11-05-2013 05:18 AM
  2. Paul627g's Avatar
    Hello,
    Being a Samsung device it shouldn't erase or wipe your data to obtain root access. But just in case I would recommend downloading Helium from the Google Play Store and using it to backup your apps/data which DOESN'T require root access. Then you can have that backup to restore in the event something does go wrong in the rooting process.
    11-05-2013 07:42 AM
  3. Golfdriver97's Avatar
    Probably your bet is to back up with helium.
    However, every Samsung I have rooted did not wipe my device.
    Sent from a Slim Tab 2.
    David Santos2 likes this.
    11-09-2013 04:03 AM
  4. David Santos2's Avatar
    Hmmm, Downloaded Helium app and Helium for Windows followed the instructions from device (PTP mode, Debugging mode etc.) yet still nothing appears on the PC application?
    11-09-2013 11:43 PM
  5. Golfdriver97's Avatar
    I would just back up the apps and keep the files on your phone. Then root.
    11-10-2013 08:26 AM
  6. David Santos2's Avatar
    You mean manually copy the .apk's and data of each app?
    11-10-2013 07:43 PM
  7. Golfdriver97's Avatar
    When Helium/Titanium/My Back Up makes a back up of say, Angry Birds, it actually makes a file. That file is what you should keep on your phone, and if you want, have a secondary on your PC.
    11-10-2013 09:34 PM
  8. David Santos2's Avatar
    If I backup the files to the SD card and perform a Factory reset, will it wipe the data on the SD card?
    P.S If I root my Galaxy Tab 10.1 3G, Is there a way to have Jellybean on it? It highest OS is only until ICS 4.0.4 or speed it up or have a better battery life?
    11-10-2013 10:09 PM
  9. Golfdriver97's Avatar
    No.
    Depending on if you like AOSP, you can possibly have 4.3 on Slim.
    From a Sprint Moto X using AC forums app
    11-10-2013 10:35 PM
  10. David Santos2's Avatar
    No.
    No for not gonna wipe the SD card when I factory reset?
    Sorry didn't understand, what do you mean by AOSP and slim? sry noob here
    11-10-2013 10:42 PM
  11. Golfdriver97's Avatar
    Factory reset should not affect your SD card.
    AOSP meaning vanilla Android, like a nexus device. Slim is a proper name for a developer like Cyanogenmod.
    11-10-2013 10:47 PM
  12. David Santos2's Avatar
    Do you know a thread that talks about step-by-step guide on how to root Galaxy Tab 10.1 3G running ICS 4.0.4? I would really like to root, and how can I prevent from bricking my tab?
    11-10-2013 11:37 PM
  13. Golfdriver97's Avatar
    Try theunlockr .com. I didn't typo.
    11-11-2013 07:54 AM
  14. Rukbat's Avatar
    Not if you copy all the files from the SD card to your computer first. Then you don't care. Having a single backup is good - unless the backup gets corrupted. Having 2 backups almost guarantees that at least one will survive.
    Golfdriver97 likes this.
    11-11-2013 07:54 PM
  15. David Santos2's Avatar
    Which stuff should I back up first? Game's/App data?
    11-13-2013 04:04 AM
  16. David Santos2's Avatar
    I backed up using Mybackup Pro and Helium app and copied the whole SD card to the computer as well. am I ''qualified'' to root now? xD
    11-14-2013 09:54 AM
  17. Golfdriver97's Avatar
    Sounds like you are good to go.
    11-14-2013 02:27 PM
  18. David Santos2's Avatar
    Successfully rooted But I would like a JellyBean ROM as I mentioned before, Is it possible to run 2 ROM's at once too? Since I would like a JB ROM and GSM ROM to be able to call using my Galaxy Tab 10.1 P-7500 Pls post with a link of a thread with the things I'm looking for, it's ok if its only a JB ROM TY
    11-15-2013 05:49 AM
  19. Golfdriver97's Avatar
    Successfully rooted But I would like a JellyBean ROM as I mentioned before, Is it possible to run 2 ROMs at once too? Since I would like a JB ROM and GSM ROM to be able to call using my Galaxy Tab 10.1 P-7500 Pls post with a link of a thread with the things I'm looking for, it's ok if its only a JB ROM TY
    As far as I know you can only run one at a time.
    But here is a good collection of ROMs: Galaxy Tab 10.1 Android Development - xda-developers
    11-15-2013 08:54 AM
  1. Soak Test Reboot problems on Rooted maxx
    By goliatham in forum Droid MAXX Rooting, ROMs, & Hacks
    Last Post: 11-11-2013, 11:47 PM
  2. Update my galaxy ace gt5830i
    By hiren in forum Samsung Galaxy Ace
    Last Post: 11-10-2013, 04:16 PM
  3. Samsung Galaxy S4 - 64gb sd card showing as full
    By Ciaran McNally in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 12:39 PM
  4. Samsung Galaxy S4 - Open case causes black screen of death?
    By mahler9 in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 09:11 AM
