So frustrating! So my wife has been using the calendar standard on her Galaxy S3 and it's become her lifeline. She needs to factory reset her phone, so I am trying to sync the calendar to her gmail account. The phone is already synced via her gmail address to email. I logged into google and went to calendar and saw nothing. On her phone, under her sync email settings, it doesn't have an option to select calendar anywhere regarding a sync. I downloaded the google calendar app and it synced up right away with the phone calendar, but again nothing changed when logging into her gmail account on another computer. I tried the option within selecting create a task and choosing under "My Calendars" the actual email address, but still no change in her gmail calendar. On her phone, under Calendars, it has "My Calendars" at the top and then the first option under is also called "My Calendars" and it appears that is where everything has gone. On that same settings page, it does have her email address listed as a heading and underneath it it shows the "contacts birthdays," "Holidays in U.S.," and then her email again. When I click on display at the bottom, all are selected. Indeed, the only one that makes a difference when I uncheck it is "My calendars," as that was her default setting which she never changed. No matter how many times I use the settings option and sync when looking at the calendar, nothing is changing in my gmail calendar. I also already got a verification code from google calendar that I put in, but nothing. What the heck?!
