09-08-2016 03:22 AM
32 12
tools
  1. Bigred2989's Avatar
    I'm sure this has been asked about 1000 times already but I'm at the end of my rope with this. I've had my Galaxy S3 for almost a year and I just got a Note 10.1. I'm trying to get things on my phone's calendar to show up on my tablet, but nothing I do seems to make that happen. From what I can tell both devices are set to sync data between each other but it's not happening. Holidays and birthdays from syncing with Facebook show up on the 10.1 but not the tasks and events from my S3. What kind of cloud service do I need to make this work? Do I need to make my S3 sync with Google Calendar first or something, because I can't figure out how to do THAT either!?
    Slart likes this.
    11-05-2013 12:06 PM
  2. Gekko's Avatar
    yes sync everything with Google Gmail/Calendar/Contacts.
    11-05-2013 12:28 PM
  3. Bigred2989's Avatar
    I think I did that, but nothing shows up on the Google calender. I just want the tablet and the phone to share info without having to create a middleman if possible.
    11-05-2013 12:40 PM
  4. Gekko's Avatar
    you need the middleman. the middleman is Google.
    11-05-2013 02:34 PM
  5. Bigred2989's Avatar
    How do I get them to talk to Google calendar? I can't figure it out. Both devices say they are linked to it, but nothing freaking happens.
    11-05-2013 03:11 PM
  6. Gekko's Avatar
    check the calendar app settings.
    also
    make sure this is installed -
    https://play.google.com/store/apps/d...calendar&hl=en
    Patsy Wayne likes this.
    11-05-2013 03:22 PM
  7. Bigred2989's Avatar
    also
    So how do I get that app to have all the stuff from my S Cal on it? You aren't expecting me to manually add everything, are you? EVERYTHING on my phone is set to sync with Google, but nothing is happening.
    11-05-2013 03:39 PM
  8. Gekko's Avatar
    you need to ask this in the S3 forums. i don't have an S3 so i'm not familiar with their proprietary Calendar App. but if you truly have settings set to Google sync - it should work. obviously something is set up wrong.
    11-05-2013 03:44 PM
  9. Buddu Chill's Avatar
    I am having exaxtly the same issue. I am having to manually input everything on both devices, I have a google account and they are synced I would appreciate any help
    01-05-2014 06:10 AM
  10. Bigred2989's Avatar
    I actually figured it out on my own by accident awhile ago but never posted about it here. When making or editing an event, press on the calendar tab and select a calender with your email in it, such as Samsung calendar and will start sharing it with your other devices. For some reason the default, "My Calendar", doesn't post to the cloud.
    01-05-2014 08:41 AM
  11. Larg's Avatar
    So, on"My Calendars" on my S3, i have added the word "S Planner". Didn't solve the problem. The message above seems to say that you can't sync two Samsung calendars (S Planner on the Note 10.1 and Calendar on the S3) without using Google calendar. That sounds nuts to me.
    01-07-2014 06:17 PM
  12. roxigrrrl's Avatar
    May seem insane, but it DOES WORK! YAY. Shame on samsung for not making it easy!
    01-12-2014 11:13 AM
  13. mkriechb's Avatar
    bigred 2989 had the right procedure. You can't catch up but can do this with all new entries
    Slart likes this.
    01-23-2014 07:33 PM
  14. Melissa Dunajski's Avatar
    Thank you! This worked perfectly - My Calendar doesn't sync with anything but selecting your email address calendar works !
    02-15-2014 09:41 PM
  15. kathleen carr's Avatar
    I have downloaded passport and tried to sync - nothing. Should I do this on computer, did it via tablet. So over this. Directions should be in writing somewhere.
    02-16-2014 01:56 PM
  16. Jessica Askew's Avatar
    I think I am just out of luck, if I'm understanding the thread.. My issue: I cracked the screen of my galaxy s3..got a replacement, & all of my past calendar data is gone. It's like a journal to me, & I'd really like to know if there's a way for me to retrieve it..
    I'm super pissed at myself for getting caught up in Samsung's pretty calender pictures & interface, because they are evil. Not only should this be easily avoided, it's like they did this purposefully.. But why? Why would Samsung stiffle progress made by Google? I don't get it. (if I had to guess though, it probably has to do with $)
    Thx
    03-30-2014 11:47 PM
  17. Debsmlake's Avatar
    If you want to take the time to do it....you can catch up with old entries by just pulling up the day, change to your email calendar option and save. It will then sync to both.
    05-01-2014 12:22 AM
  18. alben77's Avatar
    05-11-2014 10:08 AM
  19. jlj93byu's Avatar
    So frustrating! So my wife has been using the calendar standard on her Galaxy S3 and it's become her lifeline. She needs to factory reset her phone, so I am trying to sync the calendar to her gmail account. The phone is already synced via her gmail address to email. I logged into google and went to calendar and saw nothing. On her phone, under her sync email settings, it doesn't have an option to select calendar anywhere regarding a sync. I downloaded the google calendar app and it synced up right away with the phone calendar, but again nothing changed when logging into her gmail account on another computer. I tried the option within selecting create a task and choosing under "My Calendars" the actual email address, but still no change in her gmail calendar. On her phone, under Calendars, it has "My Calendars" at the top and then the first option under is also called "My Calendars" and it appears that is where everything has gone. On that same settings page, it does have her email address listed as a heading and underneath it it shows the "contacts birthdays," "Holidays in U.S.," and then her email again. When I click on display at the bottom, all are selected. Indeed, the only one that makes a difference when I uncheck it is "My calendars," as that was her default setting which she never changed. No matter how many times I use the settings option and sync when looking at the calendar, nothing is changing in my gmail calendar. I also already got a verification code from google calendar that I put in, but nothing. What the heck?!
    05-28-2014 04:45 PM
  20. Steriaz's Avatar
    thank you Bigred2989. I was ready to smash my phone it is working now.
    Main thing is to " not use " MY CALENDER
    06-01-2014 04:35 AM
  21. Steriaz's Avatar
    forget about My Calender . use " Samsung Calender " with your gmail Just as Bigred2989 says
    06-01-2014 04:39 AM
  22. jmagid51's Avatar
    Bigred, thanks for the posting. I just went from an S4 to an S5 plus a Tab3.0 and couldn't get the calendars to sync .... very frustrated till I read your post ... I owe you a cold beer. Thanks.
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
    06-09-2014 09:44 AM
  23. ShaggyKids's Avatar
    So where do you find the Samsung calendar and the S-Planner?
    I have Samsung Apps on my Samsung 10.1 2014 tablet running 4.4.2 but I do not have this app on my phone running 4.4.2. So how come I don't have the same Samsung stuff on both devices?
    Went to the Samsung apps link cannot find anything called Samsung calendar still have to go look for the S-Planner.
    Notes from Deb's Note 3
    06-09-2014 01:48 PM
  24. jmagid51's Avatar
    Deb,
    The Samsung calendar is the stock calendar on your device.
    06-09-2014 03:03 PM
  25. BucktheGoalie's Avatar
    Not sure if it's the same issue but it is similar!
    I use the Google Calendar downloaded from Play Store. Since my Samsung Note 10.1 2014 Edition updated to KitKat 4.4.2, the Google Calendar no longer has the vertical elliptical in the top right corner for 'Settings' is no longer available. Only things visible are the TODAY icon and NEW EVENT icon.
    We use multiple calendars to keep our 3 kids, my wifes, and my 2 calendars separate. All 7 are shared to each email acct so everyone can view each others. After the update, I can only see my 2 and one of my kids. The others are not available!! Now, I long in with the exact same email address on my Droid Razr M phone, Android version 4.4.2 and I can see all of the calendars!
    What's different??
    06-16-2014 07:03 PM
32 12
  1. galaxy s4 soft bricked HELP NEEDED
    By DyslexicTurtle in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 11-07-2013, 11:18 AM
  2. Replies: 5
    Last Post: 11-05-2013, 04:45 PM
  3. HTC One won't turn on!! Please help!!
    By alizonmi in forum HTC One M7
    Last Post: 11-05-2013, 03:28 PM
  4. Nexus 7 2013/Nexus 10: Pre-Purchase Questions
    By mtbvfr in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-05-2013, 12:01 PM
  5. How to set the length of alarm going off?
    By Ares125 in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 11:43 AM
