Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Harry Wild
    Harry Wild's Avatar
    Posts
    Global Posts
    474 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Question on desktop web browsing!
    I just found out by accident that the Android OS on a tablet only lets you browse using a mobile version unless you are using pure Google "Android" like in the Nexus 7. I found that you can switch from mobile to desktop with an option at the menu on top of the Nexus 7. But it start up again on the mobile version. Is there an option that you can set up in the setting menu to default always to the desktop?
    I trying out Samsung, LG and Kindle 7" and could not change it to desktop format.
    What size tablet is required to have a desktop web browsing screen appear?
    Is there away to do it in the setup of these other tablets or can you do it with an Android "app".
    Coming from both a Windows phone and Apple iPad environment.
    Thanks.
  2. #2
    Mooncatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Question on desktop web browsing!
    I'm not sure if you can force a desktop version by default, but maybe I can clarify something for you. The size of tablet doesn't affect what version of a website you see. The site checks what type of browser you're using, I.e. a mobile one like on Android, then sends the mobile version if it's setup to do so. What you may need is a browser that essentially tricks a website into thinking it's a desktop browser. I don't know if that even exists as I haven't seen an app suitable for a similar problem I'm having.
    I usually like a mobile version of sites on my phone, but occasionally I like to switch to desktop. Some websites will ignore the desktop view request and only show the mobile version. To paraphrase a comic I heard about...
    Server: Hey, I see you're on a mobile browser. Check out our spiffy mobile site version!
    Phone: That's nice, but I'd like the full version, please.
    Phone: :rolleyes:
  3. #3
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Most browsers (including the stock Android Browser and Chrome) will have an option in their menu for something like "Request desktop site." If you dig deeper in the settings, you might also find an option for "User agent," which is how you can set the default for how your browser requests pages (i.e., as a mobile site or as a desktop site). However, with some sites, even if you request the desktop site, it might still force the mobile site. In this situation, scroll down to the bottom of that mobile site and see if there's a link that says "Full Site." That should bring you to the full desktop site.
    Harry Wild's Avatar
    Posts
    Global Posts
    474 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank for the feedback. I going to ask an acquaintance that is an Android fanatic to see if be has a suggest. I think maybe a different web browser might be key.
    I going to see if he has a couple of web browsers on his tablet and I will try them out to see if I can set one to desktop format.
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    A few good 3rd party browsers are Dolphin, Boat Browser, and Maxthon. Give them a try.
  6. #6
    Algus's Avatar
    Posts
    Global Posts
    801 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use Dolphin and set the user agent to desktop. This works great on my Note 3 and helps me take advantage of that big 1080p screen.
    Sent from my Galaxy Note 3 using Tapatalk 4
    Harry Wild's Avatar
    Posts
    Global Posts
    474 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks B. Diddy and Algus!
    I will check Dolphin among other Android web browser out!
    Harry
    B. Diddy likes this.
  1. Google Hangouts won't send MMS on GS4
    By kabutar in forum Samsung Galaxy S4
    Last Post: 12-31-2013, 02:58 PM
  2. Delete recently dialed numbers on Galaxy S3 AT&T
    By Singar Singer in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-07-2013, 05:56 PM
  3. Replies: 0
    Last Post: 11-07-2013, 05:08 PM
  4. Replies: 1
    Last Post: 11-07-2013, 04:47 PM
  5. Contact info not showing on phone call.
    By Floridadomer in forum Samsung Galaxy Gear
    Last Post: 11-07-2013, 04:31 PM
