1. Mark Tighe's Avatar
    Hey guys, first post here.
    I'm trying to upgrade my Galaxy S4 from 4.2.2 to 4.3, mainly so I can use the Galaxy Gear which I purchased.
    I've read online that the update is out, but when I go to update the software in my phone it tells me that the latest software is up to date.
    I'm located in Canada if it means anything, and any information is appreciated. Thanks!
    11-12-2013 09:11 PM
  2. Mark Tighe's Avatar
    Guess I'll try elsewhere
    11-13-2013 12:23 PM
  3. FASTEDDIE427's Avatar
    im also curious i want to go to 4.4 but i might have to root my phone just to do it
    11-13-2013 02:26 PM
  4. Rukbat's Avatar
    The update process is a multi-step process. Google writes a new version of Android. The phone manufacturer takes that update and adds its own stuff to it. Then they make a separate update package for every phone they're going to issue the update for. (This means that, for instance, there's a 4.3 update for the S4 for AT&T and a different package for the 4.3 update for T-Mobile.) Then the manufacturer send the update packages to the carriers. Each carrier pushes out the update according to its own schedule. (There are intermediate steps, like Samsung writing an AT&T update, AT&T getting it, complaining about something, Samsung rewriting that thing, sending it back to AT&T, etc.)
    So from the time the update is announced to when your carrier pushes it to your phone could take a couple of weeks, or it could take a year or two. Guessing what the weather will be in Toronto on September 15, 2135 is a lot easier than guessing when you'll be getting an update.
    11-14-2013 11:48 AM
  1. Kit Kat is starting to roll out today!
    By Choorp in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-15-2013, 09:29 PM
  2. Replies: 1
    Last Post: 11-15-2013, 11:04 AM
  3. Does your YouTube take awhile to load?
    By MONDINGO in forum HTC One M7
    Last Post: 11-14-2013, 02:46 AM
  4. Worried to change over ?
    By ROADDOG64 in forum AT&T Galaxy S III
    Last Post: 11-13-2013, 12:14 PM
  5. KitKat rolling out to Nexus 7 WiFi (2012 & 2013) + Nexus 10
    By hichris123 in forum Android 4.4 KitKat
    Last Post: 11-12-2013, 11:31 PM
