1. Amin09's Avatar
    My galaxy s4 wifi usage statistics shows sending and receiving data of almost 2gb since last charge less than 15 hours. But I didn't use Internet that much. I used Facebook for less than hour. And visited 2 or 3 sites. Didn't download anything.
    So why is it showing that much data sending and receiving?
    Please help me with this.
    Best regards
    11-17-2013 03:53 AM
  2. Haalcyon's Avatar
    I'm not sure what culprit may be but one work-around could be to use an app that disables WiFi when the screen is off. Juice Defender does this. Not only may it resolve your problem but it just may grant you some extra battery points too. Hopefully, you'll receive other advice as well.
    11-17-2013 08:22 AM
  3. Rukbat's Avatar
    How often are you syncing email? Contacts? Calendar? Run My Data )free at the Play store) and it;ll show you what's using data.
    11-17-2013 10:25 AM
  1. Need some help - flashing rom problem
    By Celso74 in forum General Help and How To
    Last Post: 01-31-2016, 11:34 PM
  2. Touchwiz help
    By Hghlndr in forum Verizon Samsung Galaxy S4
    Last Post: 12-11-2013, 09:30 PM
  3. Moto X with Republic Wireless?
    By Samzzie in forum Moto X (2013)
    Last Post: 11-24-2013, 04:05 PM
  4. problem with stock music player app
    By Thien425 in forum General Help and How To
    Last Post: 11-17-2013, 11:09 AM
  5. Replies: 0
    Last Post: 11-16-2013, 11:11 PM
