Galaxy Note Won't Turn On!?
seniorita
Never had any problems, but just today, my phone just shut off. When it shut off, it kept vibrating, just small pulses over and over until I took the battery out. When it shut off, it had 100% battery, so I put the battery back in hoping it would turn back on. The samsung logo/boot screen came up, then it just shut off. It does this repeatedly. I tried putting it into recovery so I can reset it, but it doesn't boot into recovery or download mode.
Strange things: Whenever I hold down the volume down key, it does the vibrating pulse thing until i take my finger off it. And when it's on the charger, it does the vibrating thing the whole time until I unplug it, even if the battery isn't in it.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Unfortunately, I think this is the equivalent of the Blue Screen of Death for Windows PCs. Since you can't get into either recovery or Download mode, I do not know of any fix for your device.
Kimberly Ryan
