Folder Icons
Shadnic
475
35
28
Is there any way to change the standard folder icon to anything other than that plain off-white folder? I'd love to be able to choose an app icon to use as the icon for a folder!
I'm on a samsung epic running stock touchwiz at the moment if that matters.
frunkiss
185
I use App Organizer. It allows you add programs to certain "labels" then add a 1x1 widget to your homescreen and change the icon.
Apps Organizer
by Fabio Collini
>250,000 downloads, 10072 ratings (4.6 avg)
Free
Below is my main homescreen, the top 4 icons (Internet, Games, Tools, Multimedia) are folders from App Organizer. Those are default icons, but you can use your own images.
Reactions: hokuSai101
