Key ring?
DenverRalphy
Retired Network Mod
May 11, 2010
518
54
Are you referring to a password manager? Or a rewards card key ring? (There are similar named apps for both).
If you're taking about a password manager, I personally use and recommend Safe In Cloud.
SwiftKeyed/Flowed via Tapatalk 4 Beta
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
It either works great or doesn't work, depending on the scanner you're trying to get to read it. There's an app called Beep'nGo (free on Play) that's supposed to send an IR signal to the scanner (from those phones with IR LEDs) that should make it work better. I've downloaded it, but haven't had a chance to try it out yet.
Ellie10
