Virgin mobile Samsung galaxy s3 help
steveazusa
Active member
Dec 6, 2011
33
Hi i updated my s3 to 4.3 when i root with odin it says pass when i check on my phone it says no! What's going on! It was rooted fine before now it won't!
steveazusa
Active member
Dec 6, 2011
33
I know it did so when i went to try and root it again with the same procedure with odin it passed so as i opened up titanium backup it says I have no root permission. So now i get this pop up saying unauthorized access to a secured area has been blocked i also noticed there's no more USB debugging option the developer options are gone super user isn't there either i don't know what's going on
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,364
110
63
Sorry, I meant as far as I know there is no root method for Samsung on 4.3
From a Sprint Moto X using AC forums app
Golfdriver97
Moderator
Dec 4, 2012
35,364
110
63
The file you installed via Odin successfully flashed... It just didn't do what you wanted it to.
steveazusa
Active member
Dec 6, 2011
33
I know what you mean my phone got rooted with custom recovery but for some reason su doesn't read my root but TB does and when I go into root Explorer it won't let me delete all the knox system apps weird but as long as i got a partial root!
- - - Updated - - -
I used that yes
seniorengineerdood
