Results 1 to 3 of 3
    Default SAMSUNG GALAXY S3 it says its 100% battery then in 5 secs its 20%
    please help. this happened more than 3 times
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,864 Global Posts
    ROM
    Stock Moto X
    Default Re: SAMSUNG GALAXY S3 it says its 100% battery then in 5 secs its 20%
    Quote Originally Posted by DJ REGGIE View Post
    Welcome to the forums.
    The battery may possibly be going bad. Ordering a new one wouldn't be a bad idea. You can order one here: ShopAndroid - #1 Store for Android Accessories
    For the one you are currently using, I would remove it and see if you can see any bulges in the battery, look at the connection pins, etc. If that all seems good, I would turn off the phone and let it completely charge while off, and see what happens.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
  3. #3
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    And in 5 seconds more, does it come back to 95%? Then the battery has a dendrite. It's a manufacturing defect (but try to get them to replace it under the "manufacturing defects" warranty).
    Does it come back to 5% and stay there, or drop lower? It's either a bad battery, or something in the phone is shorting, killing the battery very quickly. (Only monitoring the current drain at the battery terminals over a few of these cycles will determine which.) But you can get a couple of new batteries and a charger from some Amazon partners for bout $15 for the package.
  1. No Lockscreen options in 4.4 with Sense?
    By EverNap in forum HTC One
    Last Post: 02-14-2014, 03:38 PM
  2. Droid Maxx mms Group text vs. Galaxy S4 (native sms apps)
    By beeare in forum Motorola Droid MAXX
    Last Post: 12-04-2013, 04:14 PM
  3. Usb cord broken when cutting and pasting photos to computer..files lost. galaxy s4
    By sadfacemcgrumpies in forum General Help and How To
    Last Post: 12-03-2013, 11:03 PM
  4. Samsung S3 Battery life - Is this normal
    By dodid0 in forum Samsung Galaxy S3
    Last Post: 12-03-2013, 10:44 PM
  5. Screen cracked to pieces while in my pocket?
    By campuscop2003 in forum Google Nexus 5
    Last Post: 12-03-2013, 04:52 PM
B
