My notification is way too small all it is, is just i tiny little slither at the top and I want it to appear on the middle of the screen or bigger when i recieve a new message I am using a Telecom R83 using Android 4.1.
Pull the notification bar down and you;ll get a list of all the things you're being notified about. If you want a text popup widget, there may be an app like that, although I've never looked for one.
