Results 1 to 4 of 4
    Default Message notification too small
    My notification is way too small all it is, is just i tiny little slither at the top and I want it to appear on the middle of the screen or bigger when i recieve a new message I am using a Telecom R83 using Android 4.1.
  2. #2
    Rukbat's Avatar
    Posts
    ROM
    X-Note7.0.1
    Default Re: Message notification too small
    Pull the notification bar down and you;ll get a list of all the things you're being notified about. If you want a text popup widget, there may be an app like that, although I've never looked for one.
    I know the bar but yeah i want a widget
  4. #4
    Welcome to Android Central! How about Notify Lite?
B
