Results 1 to 3 of 3
    Default Some apps wont work on 3g
    Fb chat for instance never works on 3g
    Also, flipboard, Twitter dont work sometimes.
    And I dont get all notifications while connected to mobile data network
    Thanks
    Sent from my GT-N7105 using Tapatalk
  2. #2
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Default Re: Some apps wont work on 3g
    Are you talking about the difference between 2G and 3G? Definitely. 2G is talk/text.
    Are you talking about the difference between 3G/4G and wifi. Sure - some apps are written to run on wifi and have never been redone to run on cellphones.
    Are you talking about the difference between 3G and 4G? That would be your carrier's fault. Most apps can't tell the difference. The ones that can are those that deal with that difference - like an app that tells you whether you're on 3G or 4G.
    thank you for your response
    I was talking about using apps on data connection (any) and using apps over wifi. Only wifi was working
    I called the carrier, they fixed it for me. There were some settings left from my previous phone, a blackberry
    Now it works!
  1. [APP][2.1+] Christmas Baking Recipes App
    By saroyama in forum Android App Inventor
    Last Post: 12-05-2013, 02:06 PM
  2. Need Help Deciding on a Tablet
    By Akashd in forum General Help and How To
    Last Post: 12-05-2013, 09:05 AM
  3. Sprint HTC One - Unexpected UI Errors and Force closing apps?
    By PolishDUMA88 in forum Sprint HTC One
    Last Post: 12-05-2013, 07:45 AM
  4. Did anyone try Run In Crowd on their G2?
    By heading4tomorrow in forum LG G2
    Last Post: 12-04-2013, 10:40 PM
  5. Handwriting apps with or w/o OCR
    By gm10 in forum Google Nexus 5
    Last Post: 12-04-2013, 08:24 AM
B
