How do I get my Sony Xperia M out of a boot loop?
Md Alt Ahmed
10
my sony xperia m is stuck on boot loop
hello guys am in very dangerous sitution so please please guys help me out .last night i rooted my phone and it was perfect but today i saw an video on youtube showing how to make status bar transperent like android 4.4 in that video he said it is a app runs on rooted device .the app name was framework some thing like that i opened that app and clicked on frame work it ask me to grant root access i gave it and clicked on install/update and first time it restarted after restarting it once again i opened that app and did the same process .then thhe output was successfully created new partition and restarted and got stuck on boot loop and i cannot do any thing when i connect it to pc for pc companion the pc is not recognising the device so please please please help me out am very scared this was the first time i did some expirement on my phone but i lost so help me .thanks in advance
Re: my sony xperia m is stuck on boot loop
waste site bloody forum
When you rooted did you install a custom Recovery, such as ClockworkMod? If so, you can reboot into recovery, select the factory reset and wipe cache options then reboot. Also, you may be able to re-flash the ROM or flash a new ROM to get the device back up and running - see if that helps.
no i did not do any such thing . i tried to flash a rom using fastboot but it gives me error "archive do not contain android info.txt" when i get a android info.txt it asks for boot.img when this is also done it ask for boot.sig next it asks for system.img system.sig boot.sig at last recovery.sig recovery.img after long google search i got the files at last it says failed to download signature my internet is fast and can you suggest me a rom which contain all of these
You'll need to install a custom recovery to flash a ROM. XDA might be your best bet for that. Since I don't have the device I can't help you with a ROM to use or don't know if you can install stock firmware to get it booted.
If you're looking from assistance from the forum members, posts like this are not the right way to go about it. I suggest that you read the forum rules and make the effort to keep the discussion civil.
Sent from my Galaxy Note II
i was so worried about my device so i posted my question but no body was helping so i wrote in that way so iam sorry for that
Hello,
You are facing Bootloop Correct?
this might happen if you try to load any other rom. or img, etc,
TO REPAIR:
1> Download this file. from here this is the ftf file that you'll need...
https://mega.co.nz/#!BJcWiLIK!dqwBZAytT0fXSJi9NBSUlx9mRHBGaF3JvbqTczY1vMo
2>Download Latest Flashtool. from here.
flashtool-0.9.10.2beta6-windows
3> Procedure
After installation of all above requirements
+Open the Flash tool folder (usually C:\Flashtool).Find folder named Driver. Run the program named "Flashtool-Drivers",check all the options under "select component to install". Click install
+Come back to Flashtool folder find folder named "firmwares".Copy downloaded firmware files(.ftf files) to "firmwares" folder.
+Open flashtool.exe connect the phone using USB cable (in Mass Storage mode). You can find your Phone details at INFO log.
+Click on the thunder icon , select Flashmode from mode selector window and click ok.
+Next you'll see a firmware selection window. Select your Phone's firmware from the list, check wipe data and wipe cache if you need clear all your previous apps installed. Leave all other options and click Ok.
+For some phone models Flash tool will say to disconnect and reinsert battery, then connect phone by holding "back" or "home" button (for some phones have touch sensitive home and back buttons they try with pressing "volume down" key ).otherwise skip this step
+Wait until the process complete. When INFO log shows finished , device disconnected , you can switch on your phone . It'll take 10-15 minutes for first boot .
You Cannot boot the phone correct? Complete till the second step.. and then remove your battery and put it back in 10-15 seconds....then hold volume down button(only that) and insert your usb cable it will say as device connected in flashmode... then follow from step 4 and leave step 6..... just select the firmware and it might be named as C190X and at right bottom click the button flash... you're done... congrats your phone will boot in 10-15 mins or less.....
thank you,
Rahul (Sony Official)
Sent By- Sony Xperia Z2.
I had this problem, to remedy it I used the pc companion like so
Turn the phone off and disconnect it from the computer
1. Disregard any instructions to connect the phone until you complete step 9
2. In the welcome screen you will see the different modules available for you including the "support zone" option. Click on "Start" below it.
3. On the next page Click on "Start" under "Phone/Tablet Software update"
At this point if you get an error stating that "unable to install update components" or "server is bussy" Please proceed to step 12. If you not see that error then continue with step 4.
4. The program will show a window saying "Could not find phone/tablet". Click on the option below that reads: "Repair my phone/tablet" the program will issue you a warning on the content that you will lose during the update
5. Choose the option to continue.
6. The program will issue a final message warning you of possible data lost during the update. Click on the checkmark and then on "Next/Continue".
7. After that, the program will download the necessary information (5 to 6 minutes) and it will present you with a list of phones.
8. Choose the Phone from the list then click on "next" then you will see a new section telling you how to connect the phone. (don't connect it yet)
At this point the phone must be off and disconnected from the PC.
9. Connect the cable to the PC not to the phone, then wile pressing and holding the indicated button (in the steps on screen an specific button will be shown for you to press on the phone) connect the cable to the phone and keep holding the indicated button until the program says "the update of your phone has started..." (in some cases a message of "Installing drivers" will appear before the message of "the update of your phone has started..." is shown.)
10. If you failed to follow the steps correctly the phone will turn on and it will request that you "Proceed with the following steps, slide down the notification bar", If this happens disconnect the phone from the cable, turn it off and repeat from step 9).
11. If the phone is connected properly, PC Companion will proceed with the update ( It will tell you to let go of the back key) then wait for the update to finish and follow instructions on screen to disconnect the unit.
Dear customer,
12. If "unable to install update components"
1. Close Pc companion
2. Install Java from: java.com: Java + You
3. start Pc companion again and try to do the software unlock process once more.
Note: If you wish only to update the unit wait for the program to open and then select the quick link on the uper left corner that says "Update Phone/Tablet" and follow the instructions to perform the update. (the PC may request for the phone to be placed in Mass Storage mode. Do this by going into Settings>Xperia>Connectivity>USB connection mode)
Some computers may block the installation of the update service, if this happens use this:
Update service - Sony Smartphones (US) this is the Standalone update software.
If the Phone is unresponsive (Then do this extra step and when done proceed to redo the repair process:
Press and hold the power button and the volume up button at the same time for 10 to 15 seconds. This will reset the unit)
It was a bit slow on first boot but worked
I can't stay on flash mode for atleast 10sec but I can stay in fastboot for quite a very long time
thank you very much my dear brother rahularavind, you helped me lot with your guidance.you saved me lot and u brought my mobile life ack in hours.thanks a lot.
Rahularavind sir I can't open the first link you have given
Hi guys, please help, I have a simmilar problem.
I have (successfully) rooted my phone while leaving bootloader unlocked, but than I've realized that I have to unlock it in order to install CM11.
I have followed the instructions on SE folder and got the message that bootloader is successfully unlocked.
After that, the phone enters a bootloop every time I try to turn it on. Then, I've instaled CWM using flashtool and boot.img from CM11(kernel)?
Maybe the last one was bad idea, but I wanted to try to simply install new rom and see if it will help.
But I've stopped to ask for advice, is that the right thing to do or something else?
edit:
Because I've instaled CM11's boot.img(kernel) I don't know if I can simply use PC companion repair? And if I use PC companion what will happen with my root? And is it safe just to try to continue with installing CM11?
OlSkool
