Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By ZBrink
    Default Need to Recover Phone Icon on Galaxy S4
    Hello,
    I am brand new to having a smart phone and the Samsung Galaxy S4 is my first one. I believe I swiped the phone icon into trash bin as I was trying move it, it disappeared and now I cannot locate it anywhere. Can someone help me recover it??
    Thanks,
    Zack
  2. #2
    Default Re: Need to Recover Phone Icon on Galaxy S4
    Welcome to Android Central! Bring up your App Drawer and look for "Phone." Press and hold it, then drag it back to the tray. If you don't see it, make sure it didn't get hidden somehow--check your settings to show hidden apps.
  3. #3
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Or long-press a blank spot on the screen. You'll get a pop-up. Go to Apps. Look for Phone. Press it. (Then you'll probably want to move it down to the tray.)
    Thanks. B. Diddy! That worked! :-)
    B. Diddy likes this.
  1. Cracked Screen Pattern Locked...need some guidance
    By recondoc in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 01-01-2014, 11:14 AM
  2. Need urgent help with my phone
    By Sam Do in forum T-Mobile LG G2
    Last Post: 12-15-2013, 04:36 PM
  3. my s4 makes no noise whatsoever help me
    By Ashleigh Baker in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-05-2013, 05:00 AM
  4. Please help Ipad to S4 ASAP
    By j birdfx4 in forum Verizon Samsung Galaxy S4
    Last Post: 12-04-2013, 05:49 PM
  5. Replies: 2
    Last Post: 12-04-2013, 04:22 PM
B
