Results 1 to 3 of 3
    Default Help...my old phone won't turn on
    When I transferred service to my new phone Note 3...my old phone won't turn on ....A DROID Razr. I don't understand why this happened. ...can someone offer suggestions on how to turn it on..I've tried everything. ,.and I need to get some things out of this phone
    Sent from my SM-N900V using AC Forums mobile app
  2. #2
    Default Re: Help...my old phone won't turn on
    How long did you hold the power button down for? Sometimes you have to hold it down for a good 10 seconds or so. Also, try leaving it plugged into a wall outlet for a good 12 hrs or so to make sure it's fully charged.
    You could also try booting into Recovery by following these instructions:
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    1,227 Global Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    This is all assuming that the old phone didn't sit in a drawer for a year after you turned it off (which would probably have destroyed the battery).
  1. Need Help! Brick? Installed TWRP! Now stuck!
    By phantom27 in forum Verizon Samsung Galaxy S4
    Last Post: 01-16-2014, 02:10 PM
  2. docked phone not working
    By kenw55 in forum AT&T Galaxy Note
    Last Post: 12-06-2013, 03:28 PM
  3. How do I lock my nexus 4's files from pc connections?
    By smilodon142 in forum Google Nexus 5
  4. Replies: 1
    Last Post: 12-06-2013, 02:49 PM
  5. Where's the File Mgr on Nexus 10?
    By Tweaks7 in forum Google Nexus 10 Tablet
    Last Post: 12-06-2013, 02:45 PM
B
